Results 1 to 9 of 9
Thread: Squealing Brakes
    VX Executive S2
    Jul 2009
    Default Squealing Brakes
    Does anyone know how to stop squealing brakes. Cold there is no noise but after a few kms under light braking there is that annoying squeal. Has only happened since new pads and machined discs. 2001 VX II 3.8.
    VZ SV6 && 180sx
    Mar 2008
    Hot tip, reverse for about 50m, then slam the brakes on. Repeat 4-5 times.
    WTB: VZ Chasers
    VX Executive S2
    Jul 2009
    Thanx for quick reply Kal. Will try tomorrow and let you know how it goes.
    VZ SV6 && 180sx
    Mar 2008
    No worries, had the same problem with my car recently, a few weeks after installing new pads & rotors. The above trick worked great. Just make sure you try it on a secluded road lol.
    It's because they wear in a foward motion, reversing and putting on the brakes goes against the natural groove therefore causing it to be rough, which in turn removes the squeek.
    Good luck!
    Other options are to take the pads out and rub them on concrete, sandpaper. Basically anything to roughen the pad up.
    WTB: VZ Chasers
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    or just use a decent pad to begin with. Its usually the pad type that makes noise.
    VX Executive S2
    Jul 2009
    had a mechanic do the job so would hope they used decent pads. Can pads make that much difference on street cars?
    greenacc's Avatar
    VE Berlina
    Jul 2008
    absolutely.
    Mechanics will use the cheapest pad they think they can get away with unless you ask for something special
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They probably didn't bed them in properly.
    Find a quiet road, get up to 60km/h then brake HARD down to 10km/h. Avoid coming to a complete stop.
    Repeat this 5 or 6 times, when you can smell the brakes, drive around for about 5 - 10 minutes to cool the brakes down.
    Visit my Facebook page
  1. Squealing brakes.
    By 97 SEN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2010, 12:48 AM
  2. brake squealing
    By Vt-Brrrlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2009, 02:53 AM
  3. Break Squealing
    By holyfyre in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2009, 09:25 AM
  4. Squealing belts/pulleys
    By SSbeast in forum LSx Development and Modification
    Last Post: 15-05-2008, 11:56 AM
  5. squealing commodore
    By 6 SLEEPER in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 07:48 PM
