Results 1 to 4 of 4
Thread: left front door adjustment.
    VT Executive s1 clubsport bodykit
    Oct 2009
    Default left front door adjustment.
    Hey,
    new to these forums but have read many articles on here over the past couple of years.
    now i have an unanswered question.
    my left front door doesnt quite fit right. when closed it latches but not fully and you can hear it bounce as i hit bumps which sounds really cheap and annoying so i wanna fix it.
    it seems to have sagged as the paint at the bottom where the door meets the little bit you step over when getting into your car has worn away.
    there doesnt seem to be any adjustments so i figured i would have to bend the hinges just a little, but sadly i cant get the door off to do so.
    so a) are there any adjustments to fix said problem?
    or
    b) how do i get the door off?
    cheers for your help
    VX 'S' S1
    Apr 2005
    South East,Victoria
    You need to adjust the top door hinge . For this you need a big hammer and a cold chisel. Open your door and put the chisel in the centre of the door hinge and give it a few hard belts then check the door for alignment .Keep doing this till the door is aligned. Don't over do it as it is much harder to knock the hinge the other way if you go too far . Before you start any adjusting open the door and grab the bottom corner and try lifting it to see if there is any free play which could mean the hinge pin is broken or the weld on the hinge has snapped.
    Oct 2009
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Your striker sounds worn. (the latch on the handle side of the body)
    It may have also moved down.
    They come with a plastic coating around it and the plastic has come off (this will explain the door movment)
  1. [SA] WTB - VT front left 1/4 panel & front passenger door
    By gsxrdan in forum Swap / Wanted to Buy / Trade
    Last Post: 17-04-2009, 05:11 PM
  2. [SA] left hand red door
    By Phat VN in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2009, 10:45 AM
  3. Door Adjustment (VP)
    By King_berald in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2008, 02:50 AM
  4. Altezza front headlight adjustment?
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 08:48 PM
