Results 1 to 12 of 12
Thread: Might be a stupid question
    nick3110's Avatar
    nick3110 is offline 2.5" Catback
    VX Berlina S2
    Nov 2008
    Default Might be a stupid question
    As the title says,
    Car shakes violently when braking from high speeds. e.g. 110kph slowing down to 90kph.. Can especially feel it in the steering wheel.
    My guess warped discs? front?
    How much am i looking at, can i do it myself?
    p.s. on my phone doesn't like the ffs search too well :P..
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Warped discs rotors is the most likely cause. You can get your discs machined or you can buy new ones for around $50 or less if you shop around.
    Easy to replace yourself, remove wheel, remove brake calliper (2 bolts), pull disc off.
    They say you should replace the calliper bolts but I use Loctite and never have a problem.
    If you do the rear discs, make sure you release the handbrake or they won't come off.
    MY RIDE
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Last time i tried to take the brake caliper off completely and the 2 bolts were very tight so i gave up. How do you guys normally loosen them up? I sprayed WD40 but it did not help.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    use a breaker bar and a pole on the end. make sure your turning the right way, even engineers get that wrong
    VP Calais 5ltr
    Sep 2009
    West Melbourne
    Quote Originally Posted by Zuicider View Post
    ^^^^ what he said. If you are trying to undo the bolt from the outside, reaching around the disk then go in the opposite as you would sitting infront of it. If that makes sense lol.
    Quote Originally Posted by Cheboorator View Post
    I used Loctite Freeze and Release. It is awesome stuff. It actually freezes the rust and breaks it up then lubricates the bolt and coats it for future.
    You can get it from Repco or no doubt supercheap
    INNAWE (in awe)
    Noun 1. awe - an overwhelming feeling of wonder or admiration; "he stared over the edge with a feeling of awe"
    2. awe - a feeling of profound respect for someone or something; "the fear of God"; "the Chinese reverence for the dead"; "the French treat food with gentle reverence"; "his respect for the law bordered on veneration"
    The Blues Mobile
    Dec 2008
    Western Sydney
    nick3110's Avatar
    VX Berlina S2
    Nov 2008
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Cherb
    Are you talking about the caliper retaining bolts, or the caliper mounting bracket retaining bolts?
    If it's the latter, those mothers are tight and can get a trifle rusty over time. They needs lots of grunt to shift them. It's worth cleaning the threads once you have them off. I suspect they might even have Loctite on them from new.
    To the OP
    Standard discs are so cheap these days that machining isn't worth the bother - you might even find that machining costs more than new discs. Holden sell two types of disc - Delco and Standard. Delco tend to be a good deal cheaper than standard discs - stuffed if I know why. I pay $45 each trade for Delco's for the front of my VY. Just make sure you check your pads too - if they are well down, it makes sense to replace them at the same time. Also, not mentioned yet, the discs can be bitches to remove. They tend to seize onto the hubs. Once you have removed the calipers and brackets, spray WD40 around the centre hub of the disc and give them a good belt with a hammer and block of hardwood on either side. They will generally free up and you can wobble them off. Make sure you clean around the perimeter of the mounting surface on the hub and smear a little wheel bearing grease on the surface before replacing the disc. Make sure the grease is a very thin smear - no blobs.
    The Blues Mobile
    Dec 2008
    Western Sydney
    Calaber.
    I wasn't sure what they were called but its the second ones after you take the caliper of to change the pads (as an example) the second half of that is left over. I tried everything in my ability, can't get them off. So sounds like they are the mounting retaining bolts.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Calaber.
    I found that I couldn't use a socket on the rear calliper bolts due to lack of room, so I used a flat type ring spanner and tapped the other end of the spanner with a hammer. You need to hold the spanner to keep it steady while hitting it with the hammer. I do this all the time and they come undone easily.
    MY RIDE
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by accentstencil View Post
    Yeah, tried that as well. Maybe i need a bigger hammer! (btw thats not me...)
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Calaber is right, they certainly come pre-Loctite'd in the VT-VZ era, and probably well before then too.
    As for resuing the bolts, well I'll just leave these here...
    Dunno about you, but for the sake of a couple of bucks, I know what my choice is. These are brakes we're talking about here.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
  1. This might be a stupid question...
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 11:57 PM
  2. Stupid Question
    By hitman1979 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2006, 06:39 PM
  3. stupid question
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2005, 01:13 PM
  4. Stupid Stupid Question
    By habro in forum General
    Last Post: 24-09-2005, 11:51 AM
  5. Just A Stupid Question
    By Tony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2004, 09:44 PM
