just had a service done and needs these done
Please find below list on items due on VT SS:
> Wiper Blades (Pair) $9.99* (i can do myself)*
> Air Filter $19.99 * (i can do myself)*
> Brake Fluid Flush, Change & Bleed System Service $59.99 (is this price about right)
> Coolant Flush, Change & Bleed System $109.99 (is this price about right)
> Diff Oil Flush & Change $49.99 (is this price about right)
> Link Pin Bushes $109.99 - However one of the Pins are actually bent &
damaged, therefore would suggest the Link Pin Bushes & Pin Kits $139.99
> Front Lower Control Arm Bushes & Front Radius Rod Bushes & Rear Radius Rod
Bushes $749.99
(OR Broken Up - Front Lower Control Arm Bushes & Rear Radius Rod Bushes
$449.99, and than Front Radius Rod Bushes $299.99)
IS THIS A BIT EXSESIVE PRICE WISE OR ABOUT RIGHT
> Would suggest doing all the bushes at once & save on labour expense. If
you do the Front Lower Control Arm Bushes / Front Radius Rod Bushes / Rear
Radius Rod Bushes will do the labour on the link pin bushes for free (will
save about $75/$85 for free)
ALSO CAN I DO LINK PIN BUSH KIT AND THE OTHER STUFF MYSELF
I recently paid $50 for a brake fluid flush and change.
It cost me $70 for diff oil when I changed it myself.
Coolant change I do myself for the cost of the coolant, about $40-$50
Don't know about the others but the above I've mentioned sounds reasonably priced, I would guess that your quote was not from a Holden dealer for the prices You've stated? I got a reputable brake joint to do my brake fluid, would not go to Holden, personally.
