Results 1 to 5 of 5
Thread: Engine overheating.
    boohsv is offline boohsv
    vt commodore Berlina
    May 2009
    Default Engine overheating.
    My holden berlina vt 97 model kept overheating and leaking coolant,so i took it to the local garage....found out the water pump had to be replaced.after it was replaced while i was driving the heater gauge went up to hot again and steam was filling the car,coolant leaking inside car drivers side ,..took it back to the garage ang found out thermostat has to be replaced......can i do this myself and how?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Wrong put this mate, try the VT-VX section.
    Answer is easy as, if you got thermostat and new gasket, the thermostat housing is where the top coolant pipe goes into. Undo hose and get someone to hold up so you don't lose much coolant, undo two bolts and lift, pull out old thermostat, place new one in, clean both surfaces so gasket is nice and flat then bolt back together. Put hose back on and top up with any coolant you lost, literally 5 minute job.
    Ronald Reagan (1986)
    Mar 2008
    Hey boohsv,
    The solution to your problem is pretty much as acarmody, has mentioned. The only other thing that I'll mention is that you should also bleed the cooling system. We also sell colder thermostats if that helps.
    If you have any more questions please don't hesitate to ask.
    Steve
    VX Berlina
    Apr 2007
    Whoops forgot the bleed part, very important. I had to have that screw open for about 1 minute before it was only coolant coming through.
    May 2009
    Thanx 4 dat guys,,got it fixed...just 1 problem left.....why is steam filling the car thru the vents? how do i fix this?
  1. Engine 'saying' its overheating
    By Chalky01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2009, 11:49 AM
  2. VR Overheating, leaking coolant from engine?
    By Radar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2008, 03:10 AM
  3. Engine Overheating
    By dazamaz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 07:41 PM
  4. engine overheating?
    By fullaaa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 02:04 PM
  5. Engine Overheating
    By noddy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2004, 09:44 AM
