Results 1 to 14 of 14
Thread: VX Rear Bar
    VX Executive V6
    Oct 2009
    Default VX Rear Bar
    Can someone tell how to get the rear bar off a VX I got as far as all the screws but got stuck on the two sides it looks like it is pop rivited on so I did not want to drill it out but as I was pulling it off it was bending the bracket.
    Can someone help please.
    VT Calais V6
    Aug 2007
    My vt had screws where the mud flaps are and bolts inside the boot just under the lights. after that it was just a matter of unclipping the bar along the sides and it was off, not sure if vx is the same.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Hey rooey2,
    Don't drill out those pop rivits. If you pull the carpet back on the back where your tail lights are(In the boot) you will see 2 10mm nuts, undo these on both sides. Then with a little bit of force, drag it out
    Mumbo
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    I have a similar problem though
    I have undone the sides near the rear wheels, the 10mm nuts but the problem I have is those 4 plastic phillip head screws along the rear..I think Ive stripped about 2 of them, they wont come out. Is there a trick to removing them?
    I want to remove the towbar
    Voodoo Blue SSV M6 sedan
    355rwkw
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Hey Pepstar87,
    Yeah, try and get a flat head screw driver underneath them. Then get some long nose Pliers, grab around the top of the grommet and give a bit of a pull. They are bloody stupid idea to use them as you can only ever get one good use out of them.
    Mumbo
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    Thanks mate, that did it..now I have another problem.
    I think I see what rooey2 means about the pop rivets.
    There is two on each side pop riveted into a bracket that looks like its holding the rear bar on..
    What to do here?
    Anything else I have missed?
    355rwkw
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    No worries mate, I will go get a photo of what I'm talking about in my previous post.
    Mumbo
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    Cheers mate
    Cant wait to get this damn towbar off
    355rwkw
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Ok here they are
    Remove the cover, there will be 4 screws along the bottom of it and 2 plastic screw grommets along the sides.
    remove the floor for where your spare wheel is and you will see some more plastic grommets along the bottom on the inside, remove these by getting a flat head and using your long nose Pliers.
    Pull the carpet back on both sides and you will see the wiring going to your tail lights and also 2 10mm nuts. Undo the 2 10mm nuts.
    Do the same for other side
    Mumbo
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    I got it mate..
    No I need to drill out the rivets on the electricals that are pop riveted onto the rear bar..stupid cordless drill is outta battery ofcourse.
    Then find out how to remove the towbar.
    Thanks for posting that up, I got it before I checked your post.
    355rwkw
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Yeah the bumper is attached to a bracket that those 2 10mm nuts are screwed onto. No need to drill out the Pop rivets
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    Im talking about another area, the cord for the towbar is actually pop riveted into the bottom of the rear bar, the cord is preventing me from removing the rear bar, its the only thing stopping it.
    355rwkw
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Ah ok, I understand now. Its beyond me why they would pop rivet it on.
    08 SSV M6
    Apr 2008
    Central Coast, NSW
    I know, its stupid!
    355rwkw
  1. vt rear electric windows & rear speaker problems
    By dcjacko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2009, 05:40 AM
  2. VY ACCLAIM REAR >> VZ EXEC / BERLINA REAR or something of the sort??
    By josh.meaden in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-03-2009, 09:56 PM
  3. Using Harrop Adapter to fit VT-VY rear brakes to VL-VS solid rear axle
    By Surfwagon in forum Holden Commodore How-To's
    Last Post: 26-11-2007, 04:46 PM
  4. WTB lowered rear shocks suit solid rear axle
    By VS SII in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2006, 09:27 PM
