Results 1 to 10 of 10
Thread: A/C not working
    DARK SIDE's Avatar
    DARK SIDE is offline I’ll Fry Your Ricer
    2002 HSV V2 GTS Coupe
    Dec 2007
    Default A/C not working
    the air conditioner in my caprice wont work. I had the climate control on auto with the a/c on and set at 17 degrees. the air conditioner failed to cool the air after it was on for over half an hour.
    I have recently had the abs module changed, could this be the source of the problem? It was replaced with a new module not a re programed one.
    Or could it just need to be re gassed? I hardly use the a/c and it was working fine last time I used it, so I don't think this would be the problem.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could just be low on gas due to a small leak. Does the compressor clutch engage when you turn the A/C on?
    I don't think the ABS module could have any affect on the A/C.
    MY RIDE
    DARK SIDE's Avatar
    Dec 2007
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by DARK SIDE View Post
    Not sure, how would I know if it did?
    If you look at the front of the compressor wih the the A/C off you will notice the pulley is turning but the clutch ( the part in front of the pulley ) is not. When you turn the A/C on the clutch should spin along with the pulley.
    MY RIDE
    DARK SIDE's Avatar
    Dec 2007
    Just had a check then, its spining with the pully.
    so does that mean it needs to be re gassed?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I can't say for sure but that's the first thing I would try. But I would replace the seal where the pipes join the compressor becuase that's the most common place for a leak.
    Take it to a A/C specialist to get their opinion and maybe a re-gas.
    MY RIDE
    DARK SIDE's Avatar
    Dec 2007
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    and what if the clutch doesn't spin when the a/c button is pushed? i was told my compressor had leaked and id need a new one , but could it be something else?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The most likely cause would be lack of refrigerant due to a leak, it could also be a faulty high or low pressure switch among other things. Take it to an A/C specialist and get a second opinion.
    MY RIDE
    VTvoodoo's Avatar
    VT Executive S2
    May 2006
    Gold Coast
    cheers
  1. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  2. Fan not working
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 05:50 PM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  4. A/C Not Working
    By Hardstylin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 05:47 PM
  5. new hu not working
    By orbisfactor in forum Car Audio
    Last Post: 07-02-2008, 03:58 PM
