Results 1 to 2 of 2
Thread: Replaceing Power Steering Fluid
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    Default Replaceing Power Steering Fluid
    Hey just wanna ask is there a drain plug to get all the old power steering fluid out? gonna change the fluid as i dont think its been done for ages well not from me.. and roughly how much does it take to fill.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    No, you drain it from the return hose. What you do is undo all hoses, remove bottle, to drain out what you can. Put it all back except the return hose, leave it unattached from the fluid resevoir. Block the hole and top up the fluid. Run the car for 1 or 2 seconds and purge out the fluid until its bright red in colour, reattach hose. Its not much as approx 750ml is the dry fill capacity so buy 1 litre of trans dex 3. Then bleed the system by turning the wheels lock to lock with the cap off. People may like to add different or better methods, but this is how i do it. Nulon transmission/powersteering additive can be good as well to use if you have a bit of transmission fluid lying around. Otherwise Nulon Synthetic fluid is good to use in the powersteering where it would be beneficial.
  1. power steering fluid
    By -ToM- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 09:03 PM
  2. Power Steering Fluid
    By Mickyh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 05:38 AM
  3. Power steering fluid
    By 14000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 05:41 PM
  4. Changing power steering fluid
    By gogoboygareth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2006, 08:31 AM
  5. Power Steering Fluid?
    By Cody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2005, 03:58 PM
