Results 1 to 9 of 9
Thread: Power windows from Berlina to Acclaim
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Default Power windows from Berlina to Acclaim
    Hey Guys,
    I'm needing to change the doors over from my Berlina to my Acclaim and in order to do this I will have to do the power windows in the Acclaim as they came without it, however they have the plug and wiring for the Main power window Switch. I was wondering if it would be easier to change over the BCM or to go threw and untape each wiring harness. If i need to change over the BCM what else will i need to change other then the power windows? Will i also need to change over my Instrument Cluster? Any other Advice would be great.
    Mumbo
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You won't need to change the BCM or the instrument cluster. You will need the door looms, switches, fuse (circuit breaker) and relay. Series I have different plugs on the door looms than series 2.
    MY RIDE
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    So just keep undoing all the electrical tape? Will do some more tomorrow, half way there already. It really is a big bloody headache.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Why are you un-taping the looms?
    MY RIDE
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    because there is other looms attached it.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Are you putting the door looms from the Berlina into the Acclaim?
    MY RIDE
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Yes, the Acclaim has a Low BCM where as the Berlina has a LUX BCM. So thought i may of needed to swap them over.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Mumboman View Post
    If you alreay have the connector for the main switch block then your BCM is ready for power windows and all you need is the door looms. I converted my VT acclaim to power windows and that's how it went with mine.
    MY RIDE
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    OK, Cheers for that accentstencil. Will go finish pulling the looms out tomorrow. Just wanted to make sure before i went any further and made more work for myself then what i already had planned.
  1. vn berlina power windows issue
    By rawsonn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2008, 11:03 PM
  2. VT Berlina rear power windows
    By samuels in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2008, 08:11 AM
  3. VT Berlina rear power windows
    By samuels in forum Electrical Wiring / Questions
    Last Post: 17-01-2008, 06:45 AM
  4. 96 VS acclaim series 2 = Power windows??
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2006, 08:35 PM
  5. Can you install power windows on a VR Acclaim
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 06:09 PM
