Results 1 to 5 of 5
Thread: Knock In Front Passenger Side
    VT S Supercharged S2
    Aug 2008
    Default Knock In Front Passenger Side
    Ok, i've got a knock noise coming front the passenger side, It only happens when the body rolls in that direction eg. Roundabout, Corners etc.
    I've been to a local suspension place and had replaced
    Link Bush's to Front Sway Bay,
    Castor Bar/Control Arm Bush's,
    Strut top bushes & bearings
    Alignment
    Its got 18s on the front, Slightly lowered, 700 bucks down from the above and the problem is still there! Any ideas? or is it serious enough to be concerned about? They looked over everything and found the above as possibility's
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Have you ever heard the knock under heavy acceleration?
    I used to have a knock from the front passenger side under heavy acceleration and around bumpy corners.
    It turned out to be a stuffed engine mount. Check the condition of yours.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VX Executive
    Feb 2009
    I have the same problem. Buggered if i know what it is. doesnt do it under acceleration.
    Aug 2008
    Quote Originally Posted by keza87 View Post
    nah its just on corners
    Aug 2008
    after looking in the faults thread i found this
    Steering Knock - After long drives, or high operating temperatures, some VT's have an audible clunk in the front end, that may be felt through the steering wheel on turns. A possible cause can be excessive movement of the inner tie rod end of the steering rack. A revised tierod was introduced into new steering racks early in 2001.
    Could be it?
  1. Passenger side front door jam
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 02:27 PM
  2. [VIC] Front VS Passenger Side Quarter Panel
    By pugga in forum Swap / Wanted to Buy / Trade
    Last Post: 03-06-2009, 01:13 AM
  3. Vibration Front Passenger Side
    By azteche in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-11-2005, 09:30 AM
  4. Passenger Front Side Window
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2005, 10:40 AM
  5. noize left front passenger side on take off
    By wazza2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2005, 10:24 PM
