Results 1 to 7 of 7
Thread: Front wheel allignment, which items to replace?
    VT Berlina Wagon S2 V6
    Sep 2009
    New Zealand
    Default Front wheel allignment, which items to replace?
    Hi,
    Just had a look at my front tyres and it looks like the insides are wearing a bit hard.
    Rears seem to be fine .
    Before I send it out for an alignment I would like to know if there are any components that definitely would need replacing.
    Car is a VT Wagon V6 with approx 235,000 kays. not lowered.
    Cheers!
    vt acclaim gen 3
    Jul 2009
    vic
    Na mate nothing necarcerily "needs" replacing i would say just take it in as is and no doubt the blokes doin the work will know if anything is worn out and in need of replacing. If there was anything worn out it would most likely be tie rod ends, rack ends, power steering rack boots or sway bar link rubbers as these are the most common issues.
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    A Pedders $14 steering and suspension test will tell you exactly what needs replacing in your whole suspension system.
    Depending on where you take it or how busy they are, some places may just do the front wheel alignment, charge you for it and give you your keys back, not even taking much of a look at it.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Quote Originally Posted by jazza15 View Post
    They will also tell you to replace parts that are not worn and charge a fortune too.
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    Agreed!!!!!!!!!
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Haha, yep.
    I got quoted over $3000 for parts and labour. Nearly finishes doing all the work myself and it's probably not even going to cost me close to $1000.
    There was a leak in my rack which i knew about, so they said do the rack and pump and h/p hose as they were also leaking, which they weren't. H/p hose was dry as and i couldn't see any leak form the pump from clkose inspection.
    Probably could have just used that product that i heard about after i did the rack, the one that is meant to swell the seals, but oh well, too late!
    Sep 2009
    New Zealand
    I understand that radius rods can be a problem causing inner tyre wear on the front.
    What I gather the VT series 1 and 2 have a slightly different setup. something about an additional washer on right side. (according to an article on www.whiteline.com.au
    My question is: are the aftermarket kits for the radius rods suitable for both?
    BTW. no Pedders around here
    Cheers!
  1. How do you replace wheel studs - vp?
    By Timsgmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2009, 04:59 PM
  2. [HELP How 2 replace rear wheel bearings IRS
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2009, 07:06 AM
  3. Replace VY Steering wheel. After market? Another Holden one?
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-08-2008, 01:26 AM
  4. Front Wheel Hub Bearings - Cost to replace approx?
    By ciaranvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2007, 09:15 PM
  5. Bonnet Allignment
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2005, 12:12 PM
