Results 1 to 3 of 3
Thread: front wheel bearings VT
    VT Commodore
    Sep 2008
    Default front wheel bearings VT
    Does anyone know what size alan key is needed for the 3 bolts that hold the front wheel bearing assembly on a VT?
    I tried 10mm (too small), and 12mm (too big). I tried 7/16 imperial and that was too big.
    thank you
    Mark
    VT Commodore
    Sep 2008
    I am trying to do the job with an alan key which is a little too small, and found the bolts are really stuck. Does anyone have a good method for getting these things loose?
    thank you.
    Mark
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    You's must have series 1, as on my series 2 it is 10mm i'm pretty sure (otherwise 8mm, but i think that is for the CV joints in the rear). It fits perfect, no problems.
    I use a 1 foot extension bar to go over the allan key, it will get them loose. Be very, very careful if you are using a cheap set and/or removing them for the first time as a cheap allan key will twist and evetually shear at the bend.
  1. VR TO VS Front Wheel Bearings Advice
    By kowan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2011, 09:10 PM
  2. vr front wheel bearings
    By python_hunter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 08:42 PM
  3. Replacing front wheel bearings- NON ABS
    By vnv8driver in forum Holden Commodore How-To's
    Last Post: 18-06-2008, 11:40 AM
  4. Front Wheel Bearings
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 11:02 PM
  5. Front wheel bearings
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-05-2005, 01:39 PM
