Results 1 to 13 of 13
Thread: Vt a/c
    VT spac super6
    Nov 2008
    Riverton sa
    Default Vt a/c
    Just wondering if anyone knows the amount of refrigerant in a vt ac system?
    from memory its around 900grams but cant remember exactly!
    if i cant find out by tomorrow ill just go off pressures but yeah
    haha
    cheers
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
    800 - 830 as OEM. Make sure you go by weight, as the variable displacement pumps can be a pain to the uninitiated. And dont wait for it to cycle :lol:
    VT spac super6
    Nov 2008
    Riverton sa
    haha cheers mate been a good 12months since i did a vt and couldn remember
    ill be extra careful since its a brand new compressor dont wana blow 400 bucks up straight away haha
    CHARGEDVT is offline Veni, Vidi, Vici
    99' VTII S pack super6
    Jan 2007
    Melbourne, Australia
    sorry mate jus out of curiosity how much does it roughly cost for an OEM a/c compressor? need to get mine replaced soon unfortunately
    VT spac super6
    Nov 2008
    Riverton sa
    380 brand new from highgate mate thats a genuin delphi compressor
    ring em up yourself and get it posted so you dont end up paying 5-600 with mark ups through whoever gets it for you
    VT ll S Pack
    Jun 2009
    VT spac super6
    Nov 2008
    Riverton sa
    define on its way out? haha
    im replacing the compressor because the head seals are stuffed and dump the refridge in a fortnight
    you can get a "service" as such.. which just involves a system evac, flush and a new receiver drier and new refridgerant..
    theoretically the refridge isnt a wearing part in the system
    if you think it isnt getting as cold as it should be get a system service and see if it helps out (Y)
    jakstas's Avatar
    VT SS S2 M6
    Jul 2006
    Edit: typed on the iPhone after a big day. Please forgive any grammatical errors, until I get access to a pc to clean it up, lol.
    A system "service" is a gimmick. An ac system is fully sealed. If your losing refrigerant, it's because of a system leak. There are many other factors to consider, aside from a "leak" also, such as air flow, and heat transfer, as an air conditioning system is all about transferring heat, and reducing humidity.
    If your ac is "on the way out" I'd suggest a few simple checks yourself before you take it to a dealer/shop.
    Wash your condenser. The big finned core assembly infront of your radiator. Reduced airflow through this causes higher head pressures, thus reducing heat exchange efficiency, especially in stop - go traffic. Wash this with gentle running water, normal hose pressure with a nozzle is fine, any more pressure, and you risk bending fins. If your ac runs cooler whilst your driving at speed, than when your slow/stationary that would be my first port of call, as well as making sure your thermo fans are operational.
    Check your air flow at your vents. If your airflow isn't what it used to be, or you drive around with your ac on fresh air, as opposed to recirculate, then chances are, your evaporator core has a coating of dust, which when wet turns to mud, and reduces airflow, thus again reducing cooling efficiency. Smokers, I'm looking at you for this one.
    Make a visual inspection of your ac system. Look at your compressor, condenser, reciever drier, and any joins or fittings. Any oily residue you can see is a surefire sign of a refrigerant leak. Whilst this isn't easily repairable by the average guy, it will give you an idea of what to expect from the shop you take it too.
    Don't forget the obvious! Does your compressor have a belt on it? Is the belt tight? An average ac compressor needs approx 10hp to work at optimum level whilst under load, and requires belt condition accordingly.
    The front if your ac compressor is likely a two piece unit. You should be able to manually spin the front section of the pulley by hand without too much effort, If not, you may be up for a new compressor.
    Do you have ANY refrigerant if your system? Along your ac lines there will be two fitting receptacles, or service ports. Inside those are a Schroeder Valve. Same as on your tyre valve stems. Briefly press on one of the pins on those valves, and refrigerant should escape, as these are your ac system access points. This isn't technically legal, mind you, so I have to advise against it. But it will tell you if you have any refrigerant at all. If you have zero refrigerant, and you cannot spot any leaks under your bonnet, then prepare to open your wallet, as you have a leak in your evaporator core assembly.
    When your system has been running for a while, 5 minutes or so, place a hand in the larger of the two pipes on your compressor. This is your return line, or suction/low pressure line. This is the pipe that returns from your evaporator. This pipe should be cool to the touch, and noticeably cooler than the smaller if the two, your discharge line. This one will be uncomfortably hot to the touch on a correctly operating system.
    Whilst these observations are not specific to the vt/x series of commodores, especially those with variable displacement compressors, hopefully it can give you guys and insight as to what is wrong with your air con, BEFORE you hit a workshop. Remember however, that to legally do any repairs, you must be licensed by arctik, the governing body for those with qualifications in the field.
    Nothing can outweigh the ability of an experienced technician, with the correct tooling, so use thus information as a guide only.
    Hope this extends your vehicular knowledge!
    Jako
    VT ll S Pack
    Jun 2009
    awsome info write up Jako im gonna go ova a few of those thigns you mentioned, i mainly asked so i have a heads up in the future, but i deffinitly got more then i asked for, and im more then happy thanks again, awsome write up for all commo owners!
    VZ MY06 SS
    Aug 2008
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    great post jakstas, worthy of a sticky maybe mods? as A/C probs pop up all the time
    vn executive
    Feb 2009
    frankston
    hey guys i work for subaru in mentone and i was talking to the guy who comes out and does the ac units on our cars bout why the vt ac allways stops working and he said
    that holden put to much oil in them when the made them so you drain some out and change the o rings for the high pressure lines and they should be ok other wise you will just keep destroying ac compressers so put a bit less then what it says i will find out the exact amount if youse want
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Quote Originally Posted by james_sherman View Post
    From doin some reaserch also ive found that the compressors from holden had poorly designed seals so they leak easily from the unit (which mine did). Thats y i went n got an after market OEM unit that had the seals re manufactured and they also have made them so they have replacable parts now.
    i got mine off ebay from a guy called slipperypizza 4 $349 and free deleivery from qld 2 perth + new o rings and new drier, That was a sealed deal 4 me.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
