Results 1 to 10 of 10
Thread: i think my engines cooked.
    VT Executive
    Oct 2008
    Default i think my engines cooked.
    Hey guys,
    Have a VT commodore, anyway the past few months, been a little wierd to start like it kicks over, stops, then kicks over. Kinda like a dead battery, thinking its the alternator.
    ANYWAY
    Driving down the highway today everything all sweet, then bbom boom boom bbom boom.. its not a loud banging noise, sounds like an old boat i think...
    the car still runs, its just got no power... sounds like the noise is coming more out of the exhaust, im not sure.
    ive checked the spark plug covers and theyre on...
    what else could i check?
    Jan 2008
    NSW
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Quote Originally Posted by 003KWK View Post
    Hey guys,
    ANYWAY
    Are both oil and coolant clean ??? Check your leads and spark plugs
    VT Executive
    Oct 2008
    I changed all the spark plugs to NGK ones (were GM before)
    and the car started fine, and seemed to fun fine. Took it for a spin all looked good, then it started doing it again. But only lightly, and only lasts for about 1-3 seconds. At random times.
    I'm going to run it around today, and see if length of time changes it aswell.
    Would it be advisable to get some new leads? and a new fuel filter?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    check the ignition module, get under and rattle the exhaust (had the same experience when my mufflers went) could also be a burnt exhaust valve
    VT Executive
    Oct 2008
    Well, I disconnected the battery, took it for a drive and everything come good. I think because I drove about 30k's with it stuffed up the computer reprogrammed itself to run on 4 cylinders or whatever. So it was still running rough. Hasn't missed a bit now so I'm presuming it was something to do with the spark/leads.
    One thing I notice is when im sitting still, I get this tingly rattle coming from the car, but if i put it in park it sorta goes away. Any ideas ?
    VT 2
    Nov 2008
    The original problem with the hesitation on start is the same as one I have. Best guess is that its the relay that sits on top of the starter, and not battery or alternator.
    One ofthese days i'll get around to replacing it.
    Jul 2006
    Sounds like engine mounts, check when it drive and the hand brake on and someone in the car to press the brake pedal down for added safety, look under the car and see if the sump it hitting the cross member.
    Calaber's Avatar
    Calaber is online now Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Just a guess but that rattle could be the guts of your catalytic converter rattling around. If the cat's stuffed, it might also be causing a minor blockage in the exhaust which could affect performance, though I doubt it would cause the rough running you described.
    Jul 2006
    Quote Originally Posted by Calaber View Post
    A damaged cat may make ti run rough as well, playing up the oxy sensors, flow, back pressures etc.
  1. engines
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 08:23 AM
  2. cooked v6
    By redvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2007, 02:54 PM
  3. best dinner ya mums cooked ya
    By badger__rox in forum The Pub
    Last Post: 13-04-2007, 11:07 PM
  4. VR engines??
    By comblydore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2005, 12:33 PM
  5. 355 engines
    By DomVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2005, 05:44 PM
