VT V6 PCM Pin/Wire diagram
Foxmaster
Bathurst
VT V6 commodore/Hilux
I am after the wiring diagram for the PCM, trying to find the speed senor wire and the fault wire from the PCM of a VT V6 1998 can anyone help?
Foxmaster
Bathurst
Thanks Mate! is there a number above the purple wire, I think that there is more then one purple wire coming out of the PCM, I don't have it here to look at.
Thank you
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
auto speedo input is C6 and D5 from the vss to the ecu if thats what you are after
M
mwb235
Guest
Here is a VT series 1 3.8L V6 Ecotec wiring diagram for the PCM/engine.
The attached image may be too small to read as this forum doesn't allow higher resolution attachments. If so send me a PM with your email address and i'll email it to you.
For the benefit of others, see my posts in these threads for some other VT Series 1 PCM wiring diagrams (if anyone needs these please PM me with your email address also):
3.8L V6 Supercharged
http://forums.justcommodores.com.au...0-need-supercharged-vt-v6-wiring-diagram.html
5.0L V8
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/113372-vt-wiring-diagram.html
HUMBLZ
VZ
anyone know where the oxy sensor sender wire is?wanting to hook up a/f gauge to a VY
