Results 1 to 12 of 12
Thread: VT V6 PCM Pin/Wire diagram
    VT V6 commodore/Hilux
    Sep 2009
    Bathurst
    Default VT V6 PCM Pin/Wire diagram
    I am after the wiring diagram for the PCM, trying to find the speed senor wire and the fault wire from the PCM of a VT V6 1998 can anyone help?
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    purple white is speed sensor. no engine light wire, it is run over the CAN network. its all serial data between all the modules and the dash.
    Sep 2009
    Bathurst
    Thanks Mate! is there a number above the purple wire, I think that there is more then one purple wire coming out of the PCM, I don't have it here to look at.
    Thank you
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    auto speedo input is C6 and D5 from the vss to the ecu if thats what you are after
    mwb235 Guest
    Quote Originally Posted by Foxmaster View Post
    Here is a VT series 1 3.8L V6 Ecotec wiring diagram for the PCM/engine.
    The attached image may be too small to read as this forum doesn't allow higher resolution attachments. If so send me a PM with your email address and i'll email it to you.
    For the benefit of others, see my posts in these threads for some other VT Series 1 PCM wiring diagrams (if anyone needs these please PM me with your email address also):
    3.8L V6 Supercharged
    need a supercharged vt v6 wiring diagram
    5.0L V8
    vt wiring diagram
    Attached Thumbnails Attached Thumbnails VT V6 PCM Pin/Wire diagram-vt-3.8l-ecotec-pcm-wiring-diagram-resized-jpg-.jpg
    YP Executive S2
    Jun 2009
    mwb235 Guest
    VT Calais
    Apr 2010
    VZ
    Feb 2007
    anyone know where the oxy sensor sender wire is?wanting to hook up a/f gauge to a VY
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    standard V6 diagram please claudy.boulaye@gmail.com cheers
    or im after the colours for reverse lights in a vt getting converted to manual
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    Vt spac twincharged
    Oct 2011
    Portland
    Old thread but wondering if you could email me the super6 diagram pcracing@netspace.net.au
  1. I need a wire diagram for a Sony Explode
    By Yamama in forum Electrical Wiring / Questions
    Last Post: 05-06-2009, 03:46 PM
  2. ignition wire diagram for vl
    By darren1973 in forum Electrical Wiring / Questions
    Last Post: 17-02-2009, 01:17 AM
  3. 1 wire or 2 wire O2 Sensor
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2009, 10:05 PM
  4. wiring diagram for rear lights to wire in trailer
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2007, 01:48 PM
  5. orange wire and orange white trace wire - which is "+", which is "-"
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 09:28 PM
