Results 1 to 10 of 10
Thread: Urgent help needed!
    98 VT Berlina
    Jul 2009
    Default Urgent help needed!
    im trying to remove my vt's dash but when i try to remove the face around the gear stick etc, i cannot get it off. i have electric windows and where the 4 switches are it gets stuck when trying to lift the whole unit. it is kinda hard to explain. do i have to remove the 4 switches first? if so does anyone know how to?
    many thnx, salmon
    VX s
    Sep 2005
    You put your hand under the switches and push them through the housing then unplug them.
    VX s
    Sep 2005
    or if you can have a look under the switches from the gearstick side and you can see the plug just push button in and wiggle it out and its out no problems
    98 VT Berlina
    Jul 2009
    Quote Originally Posted by VRSen View Post
    i cant even get under the switches thats the problem. i cant get the face around the gear stick and the switches off the center console.
    VX s
    Sep 2005
    so the gearstick boot you cant get out either.
    Well the easy way is push the know back on grab it tight and yank up the boot is only held in by a plastic circle thing with push out clips (You will understand once you get it off)
    Other way is working from the front of the gearstick boot push it gently towrds the rear and lift up at same time
    VX s
    Sep 2005
    once you get the gearstick boot out you will see what i mean with the window switches.
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You need to prise the switch block out before you can get the console cover off. I use a thin screwdriver wrapped in cloth to avoid scratching anything.
    MY RIDE
    VX s
    Sep 2005
    i took mine of yesterday and have done it six or seven times in my car (playing around with clusters and stereo) and removed many many more working at the wreckers and the best way is you take the gear stick boot out and you can push the window switches up with your fingers with ease no chance of scratching anything.
    Auto different story you are right with the way you suggested.
    98 VT Berlina
    Jul 2009
    hey thanx everyone for your help.
    after about an hour of pushing, pulling, swearing and yelling it finally poped off. i was about to give up.
    when i got the face off eventually, i found a weird amount of tiny wood chips underneath the console? haha random aye. oh well gonna give it a good vacume tomorrow.
    thnx again everyone
    VX s
    Sep 2005
    Im guessings its a manual by your first post saying gearstick.
    I accidently found the easy way when going hard sideways using gearstick as support (so i didnt fall out the window ) the knob and boot just flew of thats when i learnt there just push on.
  1. Urgent help needed please!!!!!!!!!!!
    By helay39 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2009, 07:16 AM
  2. Urgent Help Needed
    By greenvs in forum Electrical Wiring / Questions
    Last Post: 18-02-2008, 05:14 PM
  3. urgent help needed
    By back_in_a_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2007, 05:42 PM
  4. urgent help needed
    By tomwallace in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2006, 01:12 PM
  5. Urgent Help Needed Now!!!!
    By Keesh in forum Electrical Wiring / Questions
    Last Post: 19-02-2006, 08:49 PM
