Results 1 to 8 of 8
Thread: VX Power Window Problem
    VX Executive
    Jan 2008
    Post VX Power Window Problem
    My driver's side window is stuck closed. When I push the switch down, the relay in the fuse box ticks madly away, but no movement. Is this a motor problem?
    VT spac super6
    Nov 2008
    Riverton sa
    VX 'S' S1
    Apr 2005
    South East,Victoria
    The little white plastic clips that fit in the window regulator can snap and causes the arm to get jammed. The clips are a couple of bucks each Pull the door trim off and have a look.Removing VT/VX door trim
    VT spac super6
    Nov 2008
    Riverton sa
    corrected post...
    was reading similar posts at the same time my bad haha
    VX Executive
    Jan 2008
    Thanks for the responses. All the other windows work ok (under a separate relay). Replaced the driver's window relay, but same deal. I've taken the trim off, disconnected the mechanism from the window, and tried the switch again; still clickety-click. The window itself isn't stuck, the clips are out of the guides, so does it sound like a dead motor? What do I need to replace if it is the motor? Do I need to replace the whole mechanism? Thanks in advance.
    VX Executive
    Jan 2008
    Just hooked up 12V to the unit, and it works in both directions. So what are the alternatives?
    ve wagon
    Aug 2007
    bayswater ,vic
    i had a similar problem and after swapping over all the switches it ended up being the loom in the door ( common fault) i replaced the loom and all worked well , although it had taken neally a week to work out what it was.
    "ALWAYS TURN THE RADIO ON BEFORE LISTENING TO IT"
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by berlitza05 View Post
    Exactly what I was going to say.
    MY RIDE
  1. power window problem
    By VNexecutive in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2010, 12:57 AM
  2. power window problem
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2009, 07:43 AM
  3. power window problem
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 09:15 PM
  4. VT power window problem
    By joebloggs in forum Electrical Wiring / Questions
    Last Post: 21-02-2008, 07:34 PM
  5. help! power window problem!
    By skarekrow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2004, 06:22 PM
