Results 1 to 5 of 5
Thread: Advice needed bad!
    98 Vt commodore
    Oct 2009
    Unhappy Advice needed bad!
    hi guys,
    need some advice!
    My vt commodore wont start at all.. Drove it to local Officeworks, when returned to car, itwouldnt start!! Keys wont lock or unlock car now either. checked fuses, battery, tried leaving key in ignition and waiting, still no luck? anyone know why this would happen?
    thanks
    J
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    wh v8 stato
    Mar 2009
    Kempsey, NSW
    either a dead battery in the key which is the best case scenario or the body control module has died and won't recognise the key or do any of the other things you mentioned. Mine did exactly that. Cost about $500, but I don't remember if that included 2 new keys at $75 each or not. You need new keys with a new module as they have to be matched to each other and can't be reprogrammed to another module otherwise they'd be too easy to steal.
    Once my new key wouldn't work electronically but when I manually opened the door by putting the key in the lock and turning and then put key in ignition and turned it, it started and after driving around for a while it was ok. It was the spare key and hadn't been used for months, so I can only assume that the battery in the key is rechargeable and had gone flat but charged up while driving.
    Good luck and I seriously hope it is only the key battery.
    Jim
    98 vt s pac
    Feb 2009
    Corowa NSW
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by hovo View Post
    Jim
    I'm with hovo as I have had the same experience, although it is not quite clear from the original post whether the engine is not cranking over, or is cranking over and not starting. If it's the latter and the security light is flashing while it is cranking over then the immobiliser is not turning off and that probably means replacing the BCM.
    MY RIDE
  1. Advice needed
    By nathg in forum General
    Last Post: 30-04-2009, 09:46 PM
  2. advice needed
    By matt_brown in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-11-2006, 12:09 AM
  3. Please help - advice on VQ needed
    By VHHDT82 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2006, 01:40 PM
  4. advice for who needed
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-07-2005, 05:42 PM
