Hey,
Just looking some advice ive got a problem with my VT not sarting, i have been reading through posts and getting crank angle sensor, BCM, Fuel pump, fuses, battery terminals, loose wires..
Went to the shop and came out 5mins later to the car not starting for me, it will crank over but not fire up, the key buttons have stopped working to lock, unlock and pop the boot, so i thought the battery had died in the key fob, went got the spare and still didnt work either, cleaned the key and around the connections to the ignition barrel thinking it wasn't makeing a good connection for the immobiliser, still doesn't work! when i turn the key to start it the immobiliser light goes off, checked fuses, battery terminals and for loose wires and all looks ok, left the key in on position for 2hrs to override the security system as stated in the handbook and this failed also, still cranking but not firing..
(98 VT Execetive 3.8l Auto)
Any ideas?
Thanks
body control module
Also is there a manual security override anywhere on the VT's ?...
Do the interior lights and headlights work? I'm having the same problem but i'm guessing mines the battery because i got no electrics.
yeah, interior lights and headlights working...
i had the exact same problem mate it was my key, i had to pay holden $50 to reprogram it then everything was sweet!!
If it was only it was something as simple as a key... my spare doesnt work either. I just done the error code check on it and got 12... one flash followed by two short flashes.. but i had my batt disconnectd over nite so not sure
it may just be a fuse, have a look at the bcm fuse underneath the steering wheel or the engine cont. fuse under the bonnet i think they are 10 amp
have you tried hot wiring it?
lol i was just googleing for a how to but cant find anything.. just for a temp job to get me about
all the Fuses are ok
starter relay under the bonnet?... left and right pins on the back of the ignition barrel?.. this right?..
crank angle sensor if its firing but not starting and ur lights are all on.
crank angle sensor
would the CAS stop the car from remote locking/unlocking the doors?... Spare and my everyday key has stoped
left and right pins from where you removed the start relay
