Results 1 to 12 of 12
Thread: vt aircon
    vt executive s2
    Nov 2009
    Default vt aircon
    plz help iv just brought a vt executive and stupid me didnt check the aircon, since the wrmr weather has come iv gone to use it to find it doesnt work
    it blows hot air the green light comes on but thts as far as it goes
    the heater works fine si i dont know if it needs regassing or if its the compressor
    iv checked all the fuses and air con regulator and there all fine
    ny advice would help cause i dont wana take it in to get whatever done that need to be done and get ripped off cause im a female thanks
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    There is a good chance it just needs re-gassing but you will need to go to aircon specialist to find out for sure. Do you hear your compressor cutting in when you turn on the A/C?
    MY RIDE
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Well, I have had my A/C re-gassed 3 times over the last 4 years,changing the manifold washers at the same time due to the evidence of leaking. The last time the local bloke (with basic A/C knowledge and equipment) told me that the pipes will need to be replaced next time. Bit the bullet today and took it to a specialist auto A/C repair shop, who tell me, that it has a common problem of leaking compressor seals and one high pressuredischarge pipe. One new compressor coming up, as they are a 'throw away item', the pipe he will repair.
    All up cost quoted, $1140 smackers. Due to the number of times I bloody well use the friggin thing, it makes for very expensive cooling!....phark!!!!
    vt berlina series 1
    Sep 2008
    sounds a bit excessive , surely a good one from a vt -vx will work , from the wreckers?
    VS Calais & vh sl
    Dec 2006
    deception bay
    Sounds like a standard line from an a/c specialist "yeah compressor needs replacing mate that'll cost ya a grand"
    1999 VT Berlina
    Oct 2009
    vt executive s2
    Nov 2009
    bloody hell well i hope its just the regassing that needs to be done thqats a lot of money...
    i think i can her something when i turn it on it sorta ticks over is that what its ment to sound like
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    yeah the manifold gaskets are common to leak. ive seen one of two leaking discharge hoses aswell
    May 2006
    Right, got the 'low down'!!!!!, compressor is an early VT original that are prone to leak on the end cover seals. (later VT and VX no problems)They are a sealed unit whith rolled ends, so are a bloody throw away job. Discharge hoses were also leaking, so had them repaired. System was flushed with nitrogen and cleaners, new... gas charge (with dye) , dryer, compressor, TX valve removed and inspected, checked the evaporator (in dash) for leaks plus 2.5 hours labour and the dosh just disappears from the wallet! Hafta keep the wheels for a few more years just to get my moneys worth!
    Bloke was telling me, that if you just 'need a re-gas', you have a problem as the system has a leak somewhere. Maybe ever so slight, but they will hold their gas charge for the service life if there are no leaks.
    Just my luck today as the friggin weather has turned cool, so I can't try it out!!.....LOL
    vt ss commodore
    Sep 2009
    my aircon in my vt? when i accelerate it stops blowing cold air on your face , when i back off the revs it starts blowing again . whats up .
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    check your vacum lines and vacum tank your losing vacum under accel from somwhere , check that the vacum tank hasnt been by passed
    vz acclaim
    Sep 2008
    compressors are known for seal leaks which means the gas escapes and no cooling oocurs.
    my commodore cost me $700.00 to get a new air conditioner compress fitted and gassed.
    new pipe work as well.
    shop around for price
  1. VP aircon
    By Jared91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 07:04 PM
  2. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  3. vp aircon
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2007, 09:23 PM
  4. aircon fan
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2005, 11:02 PM
  5. Aircon
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 11:17 PM
