Results 1 to 14 of 14
Thread: Dual Mass to Solid Flywheel Conversion, Who Can Help?
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Default Dual Mass to Solid Flywheel Conversion, Who Can Help?
    Evening peoples,
    Need a new clutch for my VU soon but ive heard about a Solid flywheel conversion from the standard dual mass. The Kits for the dual mass are quite expensive and if its possible to convert toa solid flywheel and let it be a cheaper option now and in the future, il take it. Can anyone expand on this for me, whats required and costs etc?
    Cheers,
    Social.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    ring adelaide clutch services or get a clutch kit from capa... think they are on special this month too
    Boonz's Avatar
    Jul 2005
    May 2004
    Have a look at the for sale section. I am selling a manual conversion that comes with a solid flywheel.
    social's Avatar
    Nov 2008
    South Aus
    VSteve, im aware of how manual conversion work mate but im converting from a dual mass to solid, i beleive theres more involved.
    Peanuts, im looking to fine out what il need to do / have done and whether its jsut a removal of all the dual mass components or something else.. Do you know the process? And i believe those clutch(s) / kits are for a v8 mate ive only got a 6
    Boonz's Avatar
    Jul 2005
    ohhhhhhhhh sprry my bad
    just needs the old flywheel unbolted and the solid one bolted back on with new bolts... replacement ones are designed to be direct changeover with no mods required
    so basically just a standard clutch change
    social's Avatar
    Nov 2008
    South Aus
    just a basic clutch change? well that sounds simple enough, anyone had any experience in a converted clutch?
    May 2004
    If you get a solid flywheel you will need a clutch plate that has springs in it. Your car is currently the other way around. It has springs in the flywheel and the clutch plate is solid.
    social's Avatar
    Nov 2008
    South Aus
    yea i gathered it was a bit wierd lol, i think il be staying with the dual mass, done some research on it n yea, so il just go spend $2000 and get a upgraded kit lol
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    VX s
    Sep 2005
    Aug 2004
    hey mate i just did a manual conversion on my vu, and put a new clutch in while i was there, i got a exedy heavy duty. comes with the solid flywheel drive plate an clutch, spigot bush thrust bearing an new bolts everything u need, jus swaps strait over and came with a tool for aligning the clutch. u can get them for around $900 maybe look on ebay
    VX S
    May 2011
    liverpool
    Default VX commodore
    hi all,
    i have a VX commodore which the clutch is starting to go, and was wondering if anyone knows the benefits of changing from a dual flywhell to a single with a heavy duty clutch?
    VU S2
    Jan 2011
    Quote Originally Posted by macca843 View Post
    hi all,
    I recently had my VU's clutch done and after research decided to pay the extra and stick with dual mass.
    Single will make it cheaper and if you need to change a clutch in the future then it could be worth it, but I can't see me owning my vehicle if it ever goes again.
    The main reason I stuck with what was designed for the car is because alot of people commented on how much noisier the gearbox becomes on a solid mass flywheel.
    I decided paying the little extra to get what was originally designed for the car was best, it'll come down to your budget and if you don't mind the extra noise in your cabin.
    Scott
  1. Wanted dual mass fly wheel
    By shaylea25 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2009, 08:59 PM
  2. Dual mass flywheel question
    By goanna_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-08-2009, 05:08 PM
  3. VS SII to vx SC + getrag 5speed exedy solid mass
    By craig84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2009, 09:54 PM
  4. Exedy solid flywheel conversion for VS V6 getrag... need help ASAP
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 03:41 PM
  5. dual mass v6 flywheel
    By vt1998 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-07-2006, 08:58 PM
