Results 1 to 17 of 17
Thread: ticking noise in L67....
    '84 VH SLE
    Mar 2006
    Default ticking noise in L67....
    Hi guys, just wanna run some symptoms by you and see if any of you have experienced the same thing.
    I just upgraded my pulley to a 10psi, pressed on, new belt on, but now when you turn the car on and upon throttle, for the first couple minutes there is a constant ticking sound that is coming from under the hood. can't tell you exactly where it's coming from, but it's loud enough to be noticed from inside the car. Ticks faster as you accelerate harder.....but after a few minutes, it stops the tick. I thought it may be tappets but thats normally caused by low engine oil. Checked that but there's plenty of oil.....mate thinks maybe it's the blower screws hitting each other and i might need to change the gears behind the snout, but i didn't have this problem before the pulley upgrade....
    ANY IDEAS WOULD BE GREAT!
    cheers in advance.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    sounds like a lifter isnt holding pressure, what oil are you running in it?? if its anything over 15w40 its probably getting a bit thick, also there could be a fair bit of carbon build up in the valley and maybe a bits dropped off and blocked the lifter.
    '84 VH SLE
    Mar 2006
    Yes I also forgot to mention....i changed the rockers as well....you think one of them is not sitting on the push rod properly?
    VS l67 statesman
    Dec 2008
    Bearings in the pulleys will make4 a ticking sound when they are especially noticable on startup and it will fade on warm up, also you may have damaged a snout bearing when you put the pulley on or it has shit itself from spinning it faster ,
    & This is what stuffed rotor pack bearings sound like
    YouTube - Eaton m90 supercharger rattle no 2
    YouTube - Eaton M90 rattle
    Boonz's Avatar
    Jul 2005
    Quote Originally Posted by emmtee83 View Post
    did you change the rockers and pushrods?? does sound like a lazy lifter tho... cos once the oil warms up it thins out and can get into the lifter easier.
    usually if a bearings gone you can put a screwdriver on the pulley nut or snout housing and put the handle next to your ear and use that as a stethoscope while the engines running
    '84 VH SLE
    Mar 2006
    you'd think if it was a bearing i would have heard it before the upgrades....yes i have changed rockers only, not pushrods....mace said they'd be fine with standard ones.
    sorry i'm new to this, but what exactly do you mean by 'lifter'?
    '84 VH SLE
    Mar 2006
    Quote Originally Posted by vsl67 View Post
    doesn't sound quite that bad....thanks anyway
    Boonz's Avatar
    Jul 2005
    go on howstuffworks.com and suss out how a hydraulic lifter works and what it does.
    i cant be bothered explaining cos you need to see the pictures aswell to get the jist of it
    vt s s1
    Mar 2009
    Is it only happening when cold starting?
    What about if your restarting when angine is hot or warm?
    VY SII HBD Calais L67
    Dec 2006
    Do you have headers? It is common for people to notice increased valve noise after fitting rockers. The valves are opening and closing faster and travelling further so that can cause the noise which can be amplified by thin walled headers
    VYII Calais L67
    VS l67 statesman
    Dec 2008
    Quote Originally Posted by chargedvx6 View Post
    ^^^ I second that
    BIG-EV's Avatar
    BIG-EV is offline Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    if its just after u did a pulley sway u may have pressed it on too far and its rubbing the snout.. i had this... does it whilst its cold when it warms it goes away and it gets faster and louder the more rpm
    '84 VH SLE
    Mar 2006
    BIG-EV: don't think we pressed the pulley on too far, met it flush with the end of the snout....thanks for the idea
    VT S: correct, only when cold starting, hardly noticeable when engine is started when warm
    Peanuts Inc.: Thanks for that, i'll head there and have a look =)
    CHARGEDVX6: no I don't have headers, but wouldn't the valve noise be experienced all the time if i don't have headers, not just when cold starting?
    Thanks for your help everyone
    '84 VH SLE
    Mar 2006
    if the valve is a bit noisy upon startup until engine is warm and oil passes through to lubricate it, is there anything that can be done to stop the noise? is it going to cause harm to the engine? and would changing the valve springs change anything?
  15. #15
    VS Calais & vh sl
    Dec 2006
    deception bay
    Firstly i would take the rocker covers of and loosen all the rockers and adjust them again.
  16. #16
    Boonz's Avatar
    Jul 2005
    if i were you i would be adding a lifter flush additive, runnin it for half an hour till the oil gets hot, drain the oil, change the filter and try running a semi synthetic 15w40 oil...
    did you have a look at how the lifter works?? it also supplies the oil to the rocker arm thru the pushrod and can do damage if it is run dry for minutes at a time
  17. #17
    SC. vt calais
    Aug 2006
    mine did that. gradually got worse, but because the noise went away relatively quickly almost like a pump cutting in thought nothing of it.now it is in my driveway D.O.A get onto it fast my man gen3 changeover for me
  1. ticking noise
    By trentvy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-09-2009, 05:26 PM
  2. Ticking Noise
    By chitchat2000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 10:35 PM
  3. Ticking noise!
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2008, 05:30 PM
  4. ticking noise..
    By matt_gotigers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2007, 09:44 PM
  5. ticking noise
    By krisjanik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2006, 06:44 PM
