Hey Guys,
Since i bought my Stato its always tracked slightly to the left even after 2x wheel alignments.
Today we rotated the tyres (Straight front to back swap on each side) And now the steering wheel is at a 45 deg angle left when driving in a straight line.
Im assuming something is wrong with the tyre/wheel that was on the front left, Anyone have any idea what?
Thanks
Dan![]()
VU wheel alignment.Can it be perfect? was on the next page but search is ur friend lol
Not the same issue, Tires aren't directional, and it tracks perfectly straight now (Different brand same size tyres on front now)
Only difference being the steering wheel isn't straight when driving in a straight line since rotating.
I once experienced a front tyre quite noticably causing the old kingswood to pull to one side. It was an identical size, brand and same amount of wear as the other 3. I solved the problem by running it only on the rear and then as a the spare. I was told at the time it was probably caused by faulty manufacture.
Seems to be the issue, couldn't get it in anywhere to be aligned today after i finished doing my morning stuff so will find out tomorrow![]()
Some people set the steering wheel straight when driving straight even though the car pulls to one side. Now that it drives straight, the wheel is out. Get it aligned again and it should fix your problem. I'm guessing one of the tyres that are now on the back was at fault.
Aligned and its fixed! Anyone know how much sway bar bushes cost :-(
Should be cheap dude... $20-50?
