Results 1 to 6 of 6
Thread: Camshaft
    VX SS 5.7 man.
    May 2009
    Default Camshaft
    Planning on putting in a camshaft to my LS1 but not too sure what it entails. Has anyone had this done? If so, what can I expect and prices. Thank, Nathan.
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    i had a cam done in mine 2 years ago
    there is a few options
    you could go
    a basic install would be
    *cam
    *valve spring
    *tune
    extras would be
    *hardened push rods
    *under drive pulley
    *double row timing chain
    *Ti retainers
    a usual cam install is around 3k
    cheers GM
    WH Caprice LS1
    Oct 2009
    Reservoir. vic
    Hey, I am considering the same, to go with new heads and valvetrain.
    Pac springs can handle .600 and roller rockers are 1.8, but at what point
    in cam spec's, (duration and lift) will I start to have a problem with valves
    contacting standard pistons?
    Will a standard LS1 grind, albeit HSV GTS spec,
    cause problems? (thinking around 207/217 116 LSA 0.500" int/exh lift?)
    Can't find any information that suggests GTS has pistons machined to
    compensate for valve clearance.
    Please correct me if I'm wrong or share your knowledge in regard to a medium street
    grind you personally know works well.
    As for price, CNC heads, springs and valves, stainless roller rockers, new head bolt kit, $2500
    I hope to pay $1500 - 1700 for Cam, roller lifters, d row chain, rods and underdrive.
    install maybe $500 or $600, then another bloody tune...
    Have fun...
    P.S. Have you considered Nitrous, only $1000 and you can do it yourself....
    ... You funny Guy, I like you...
    I kill you last...
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    Whits86 and Statesmad
    check out these two sections for info on Camshaft upgrades. prices, power output expected etc there will be info in there for sure,
    V8 Development and Modification - Just Commodores
    LSx Development and Modification - Just Commodores
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    Dec 2006
    Nowra
    Quote Originally Posted by Statesmad View Post
    Have fun...
    you wont have any issues with a GTS cam and cnc'd heads
    just make shore its a after market cam ground to GTS specs
    as the original GTS cams are weak as piss
    there have been people who have fitted 242/248 cams to standard motors without any fly cutting needed to the pistons
    but you wouldnt fit a cam that big with milled heads
    a good street cam is mid 220's like 224/228
    cheers GM
    WH Caprice LS1
    Oct 2009
    Reservoir. vic
    GMMAD, thanks for the info, sounds good...
    I kill you last...
  1. F.S: HSV R8 Camshaft
    By RebelSS in forum Parts And Other Items For Sale
    Last Post: 23-07-2008, 07:56 PM
  2. a new camshaft
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2008, 12:14 PM
  3. Camshaft
    By Nicky t in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-12-2007, 06:54 PM
  4. camshaft
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2004, 09:49 PM
