Now the question is while im waiting for the replacement is it better to A: not drive the car B:unplug the module and drive or C: Just drive around with ABS, ECU, Airbag and Engine light on???
I don't know the correct answer but I would just drive around as it is taking a bit more care.
Are you absolutely sure the ABS module is shot, because recently I learned that a faulty alternator (voltage regulator) can cause the same warning lights to illuminate due to voltages readings being out of whack, triggering warnings.
MY RIDE
i was talking to a mechanic friend and he said unplug the ABS module and start it up and see if all the lights are no longer on, unplugged it and they all are now off, except the traction control OFF light. So i'd assume thats the module, but i still might take it somewhere tomorrow just to confirm
