hey guys, wondering what to do next for my vx ss i decided it look into fitting quad tips.
wanting to have the same look as the utes with their twin exhaust outlets, wondering if anyones done it?
i know that its a bit of rootin around to get it,
wondering the costs of attempting such a thing?
keen to hear from someone out there
thanks guys
How much research have you done on this? Would it involve getting a tank from a ute or similar setup of smaller capacity?
I looked into this for my VP. Was told it was less than $1000 for a custom fabricated tank (which shocked me, thought it would be shitloads more)
Maybe ask around at a few welding places to see what it would cost for the size/dimensions you need.
Originally Posted by davway
What about using a tank from a ute, it would have the correct width and probably depth, just not sure about height and mounting points being compatible.
Fuel cell in boot, problem solved![]()
The ute tank is a different shape as well. Won't even go close. See if you can get a Monaro fuel tank. But a custom one may be cheaper.
I don't think the Monaro rear end will fit, but there are Monaro kits available for the sedans.
cool mate,yeah ima look into the cv8z rear bar also,they look pretty shmick.
i like th idea
Mr_clubsport has put quad tip on his vx clubby should give him a pm or something
just an idea
his is in the post ur ride thing he should be near the top 10 somewhere he pasted recently
did you find mr clubsport
if so im curious now what is involved with puttin quad tips on
I heard storys of cutting a section off the tank and allowing the pipe to flow along the side safe. You will lose some tank capacity.
But this custom tank sounds the better way to go.
Also a guy on here biohazard ?, He had a VZ Monaro bumper custom made to fit his VT sedan, Took a small section from a VX SS to make it work but there is your dual outlets.
Originally Posted by Yoda
benjamino if you want a custom made tank pm me
First Car: 01' VX S
Second Car: 02' VXii Exec 9C1
Monaro bumper (or even just the skirt) would need to be modified to fit.
This is the bloke you want to get in touch with about the Monaro rear bumper. I don't have his name but someone should know it by the pictures?.
You do know the monaro chassis is different to allow the dual exhaust, so even if you bought a monaro fuel tank you'd be out of luck...
A ute chassis is different and a fuel tank is mounted in a different possition aswell...
Custom tank/fuel cell or doing it the cheaters way as you posted the pic above is the only way.
CHeers
MaT
Monaro Setup
underneath of a vy ss pretty much same as your vx underneath
Originally Posted by garth
hmm.
cheaters way sounds like the goods atm.
but the pipe will be exposed because my ss bumper isnt low enough,
mr clubbys is genuine vx clubby rear bumper sits lower than mine,
hence covering the pipe in the pic..
hmm.
