Results 1 to 13 of 13
Thread: surge problems auto or diff
    VT Calais Supercharged V6
    Dec 2008
    Default surge problems auto or diff
    Ive had a quick search and cant seem to find exactly whats wrong or if anyone else has had the same problem but in the last few days ive noticed that while going up a hill my car (L67 VT Calais Auto) sometimes jerks and surges a bit under power its not everytime but its starting to concern me, at first i thought it was low fuel moving away from the pick up but even on a full tank it still does it.
    Im not sure what i could be its hard to tell where its jerking from the auto or diff or the fuel system somewhere is causing it.
    Does anyone know what could be causing it? Any sort of info would be appreciated. Thanks
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I would try changing spark plugs. It could also be a plug lead or coil that is faulty.
    VY SII HBD Calais L67
    Dec 2006
    It will be a spark issue most likely. Leads and plugs would be my starting point. Genuine leads are worth every cent IMO. Is the car boosted or running a stock charger pulley?
    VYII Calais L67
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    My money is on a faulty lead.
    MY RIDE
    Dec 2008
    the car is just stock boost no major mods yet, the leads and plugs arnt that old only 20,000ks and its just starting to do it now but oh well ill change them anyway to make sure, any suggestions on leads? I know the genuine ones are pretty good but ive also been hearing good things about eagle leads anyone had any good or bad experience with them?
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    blocked up injectors?
    run some injector cleaner through it - mine spluttered a little though mine wasnt just on hills.... so it could be the leads. or even plugs?
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Darkk_Calais View Post
    Don't buy new leads until you check them. Check the resistance with a multimeter. I don't have time now but I will post the acceptable resistance of each lead later.
    MY RIDE
    Dec 2008
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by accentstencil View Post
    High tension lead resistance limit is: leads 1,3 and 5.....10 k/ohms.
    leads 2, 4 and 6.....27 k/ohms or 17 k/ohms for supercharged.
    MY RIDE
    Dec 2008
    Vt commodore equipe
    Nov 2009
    Thats what happened to my car.... I just left it then it got worse and the throttle position sensor is stuffed well the codes say it's sticking open
    Vt commodore equipe
    Nov 2009
    Well I didn't just leave it I changed my plugs and leads n made no difference
    Commydoor's Avatar
    Commydoor is online now born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    fuel filter might be getting a bit clogged?
  1. [Ecotec] problems with my diff
    By CairnsGuy89 in forum V6 Development And Modification
    Last Post: 25-03-2009, 07:01 PM
  2. VT SS Diff problems???
    By Zool in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2009, 04:47 PM
  3. Diff Problems
    By luap001 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-01-2008, 07:43 PM
  4. diff problems
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2007, 08:23 PM
  5. vs diff problems
    By quikvskiwi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 02:22 AM
Tags for this Thread
