Results 1 to 9 of 9
Thread: can you change bearings in idler pulleys
    vs series111 ute&vt acclaim
    Nov 2009
    Default can you change bearings in idler pulleys
    i've pulled out my idler pulleys from the v6 that the bearings are shot!! but i cant seem to punch the bearings out without applying to much force so i dont break pully. Do you have to buy the hole part or can you just replace the bearing?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Usually you just replace the pulley, around $30 if you shop around. I suppose you could replace the bearing by pressing it out.
    MY RIDE
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by accentstencil View Post
    yep i agree just replace them so much quicker and easier 5 minute job if that
    VS l67 statesman
    Dec 2008
    Yes you can replace the bearings in the metal pulleys but not the plastic ones as they are sealed in,the bearing numbers are 6204 or 6304 depending on which pulley you want to do and cost about $7 each
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    The original 'plastic' pullys, as said above, have the bearing moulded in them. To press it out will break the lip holding the bearing in. The steel after market pully's, eg, K.C. brand, have the bearings pressed in, with circlip retainer , so they can easily be pressed out when knackered, and replaced.
    VY Acclaim
    Nov 2009
    Quote Originally Posted by pablo View Post
    For what the Gates pulleys are worth for a full set, including the tensioner pulley. Why bother with a steel pulley with replaceable bearings? A new set of pulleys will out last the car anyway.
    May 2006
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    I Got the Idle Pulley from AUTOBARNS, $22 and full metal pulley. No More Stupid woshing sound lol
    VT Berlina
    Jan 2006
    Yeah, I have replaced mine about 3 years ago with Holden genuine, and go figure, it is now knackered... again... but then, for the cost, cheaper than replacing the whole car...
    Bit disappointed with how long it didn't last... but then... off to buy another cause I am a sucker...
  1. ecotech idler pulleys
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2009, 09:43 AM
  2. Pulleys and bearings
    By commodorevxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2009, 06:40 PM
  3. Idler pulleys.
    By _R_J_K_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2009, 03:16 PM
  4. squeaking idler pulleys
    By black as in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2009, 10:14 AM
  5. VX V6 Idler pulleys / Drive belt
    By glenward in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2008, 07:25 PM
