Results 1 to 6 of 6
Thread: VT Berlina fan speed amplifier
    VT Berlina S2
    Nov 2009
    Default VT Berlina fan speed amplifier
    Hi guys, Holden have told me the above part wont be in stock dill at least mid december.
    The Air Con on High constantly is driving me nuts, is there anywhere else i can get one of these parts?
    Iv checked just about every wrecker in the south east of queensland with no luck, they all have tons of the normal air con resistor but none of the climate control version.
    Repco, Supercheap etc say they dont stock them.
    Calaber's Avatar
    Calaber is online now Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Quote Originally Posted by bundy_boy View Post
    Hey bundy
    Do you know if the amplifier for the VX is the same as a VY and do you know what is wrong with yours?
    The reason I ask is that VY amplifiers have a soldered flat strip running up one side, which breaks free because the solder at one end gives way. It can be resoldered easily and the amplifier can be successfully re-used. Another member of the fourm on the VY or VZ section a few months back related how he had repaired his amplifier this way and it worked ok when re-installed.
    If your amp is the same, and you can solder, it's a simple job and well worth the effort. A new amp, if you can get one, is at least $80 or so trade (at least, mine was) and once I found out they can be repaired, I re-soldered mine and keep it as a spare.
    vt berlina series 1
    Sep 2008
    where are these things located as i have the same problem , id like to try the re solder trick
    VT Berlina S2
    Nov 2009
    Quote Originally Posted by banga View Post
    Hi banga, they are behind the glovebox on the right hand side, simply unclip the electrical connection and undo by 2 screws, the ones on the berlina have a white face, and i think the standard air cons have a black face.
    vt berlina s2 supercharged
    Nov 2009
    very interested on the outcome to this problem as my vt has exatly the same problem..works fine but as soon as you accellerate the fan cuts out then as you ease off the throttle the fan kicks back in....very annoying..please keep posted ..cheers
    VT Berlina
    Jan 2012
    Hi Guys can anyone post a photo of the fan speed amplifier or describe where and what it looks like on a VT Berlina PLS?
    I removed the passengers side cover of the centre console but don't know what the F.S.A. looks like so I stopped.
  1. fan speed resistor/amplifier climate control
    By trip01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2008, 09:25 PM
  2. My VR Berlina 5 Speed
    By krizko in forum VR - VS
    Last Post: 29-08-2008, 10:18 PM
  3. fs vn berlina 5 speed v8
    By Gav1802 in forum Vehicles For Sale
    Last Post: 17-04-2008, 12:51 AM
  4. vn berlina 5l 5 speed
    By Gav1802 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 01:42 AM
