anyone got any ideas as to why my V6 VX would heat an extra ten degrees to what it normally should be? when idling the fan never used to come on, now it takes a minute and its pumping. no radiator leaks so that rules that out.
Also i think i've noticed a slight decrease in performance but that might just be summer coming along.
any ideas?
what state are you in mate?i thinks its normal to be a little hotter on hot days mine goes up a little bit extra![]()
nah its been doing it since winter, just worried it'll end up doing more damage cause its running at about 99 degrees
oh ok maybe your thermostat isnt onening all the way like it should?
do you use coolent or just water?
coolant, my dad reckons its the thermo too
by the sounds of it it would be that
there not expencive to change just do it you self
ok thanks for that
