+ Reply to Thread
Results 1 to 19 of 19
Thread: steering wheel vibration
    VT EXECUTIVE
    Jan 2006
    Default steering wheel vibration
    VT 98 - Recently had the whole front end rebuilt, new springs, struts and shockies front and back but I still feel a vibration coming through the steering wheel. It feels like you are picking up every bump in the road through the steering wheel and it is uncomfortable to drive with this constant vibration.
    The wheel alignment is perfect.
    Any answers on possibilities? Is the steering rack a possibility or neuroprene components?
    Please post any possibilities you can think of.
    Dave
    PS I dont want to sell her because of this i love my vt
    vt acclaim
    Mar 2006
    Gladstone Qld
    VT EXECUTIVE
    Jan 2006
    2000 Vx Berlina
    Nov 2009
    Melbourne Victoria
    can you feel where its vibrating from.... is it from the front or the rear... you can usually tell the difference?
    VT EXECUTIVE
    Jan 2006
    2000 Vx Berlina
    Nov 2009
    Melbourne Victoria
    2000 Vx Berlina
    Nov 2009
    Melbourne Victoria
    my brother has his done at a couple of different places.. some alignments are done dodge
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Constant vibrasion that gets bigger when going faster and is there all the time could be to do with the hubs/wheel bearings/wheels or tyres.
    If when braking - rotors.
    Have you tried the rear tyres on the front?
    and 3 Dangerous non ABS VN's
    VT EXECUTIVE
    Jan 2006
    vt acclaim gen 3
    Jul 2009
    vic
    have you had the actual wheel balance checked? also not just the balance but checked for spinning true (wheels not buckled) as wheels will spin up perfect weight wise but can still have been buckled. what was the reason the front end has been rebuilt?
    VT EXECUTIVE
    Jan 2006
    88GreenVN's Avatar
    Jun 2006
    Is the vibration more so when braking or just driving and gets wores as speed picks up?
    VT EXECUTIVE
    Jan 2006
    just driving and gets worse when speeds up but when on smooth surface everything settles down and the steering wheel does not shake. Stuffed if I know !
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Rule of thumb. Vibration under 80kph - problem in the front. Vibration over 80kph problem in the rear. Did you have your rear wheels balanced at the same time?
  15. #15
    VT EXECUTIVE
    Jan 2006
    pablo is offline Donating member pablo Executive
    1997 vt v6 wagon
    May 2006
    Could be tyres, try fitting a couple of differant wheels of one of your mates cars, Borrow a couple of spares and see what happens.
  17. #17
    VX series 2.
    Aug 2009
    if it only happens when braking, its most likely rotors.. mine has that problem, braking heavily from about 80k's.. can get machined for about $40 a pair if u take them off and take them to a mechanic..
  18. #18
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
  19. #19
    jazza15 is offline Jarryd jazza15 Executive
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by BlackVXGTS View Post
    How can any vibration from the rear transfer to the front and up the steering?
    Warped brake rotors vibrate at above 80km/hr don't they? - This is not another suggestion for your problem.
    Over inflated tyres would excentuate the problem at most and i'm sure he has explored different tyre pressures.
    I am having a similar problem, mine is vibrating at above 80, have overhauled everything in the suspension, except changing strut top mount and bearings (which are gone). Keeping existing shocks as they are good according to pedders (good means at least 10,000 km more). I don't think there is any brake shudder at all which keeps me away from changing rotors.
    These sorts of problems seem to have very specific solutions, not general solutions like wheel balances and allignments. (I've had a few myself from different places which has resulted in the problem only being dampened at the most). Changing radius rod bushes to urethene ones also helped dampen it as well. new steering rack btw.
    I just hope it is not due to a slightly bent k frame or something bad like that, cbf changing that.
+ Reply to Thread
  1. Steering wheel vibration, pulsing
    By Letscruise in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2009, 02:05 PM
  2. Steering wheel vibration
    By dans_vz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-06-2009, 12:14 AM
  3. Vibration Through Steering Wheel
    By DannY_P in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2006, 08:26 AM
  4. slight vibration from steering wheel
    By Takhuma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2006, 08:11 PM
  5. slight vibration from steering wheel
    By Takhuma in forum General
    Last Post: 19-06-2006, 04:16 PM
