Results 1 to 4 of 4
Thread: Heavy steering in a VT
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Heavy steering in a VT
    Did a search, game me nothing of value.
    Stock VT Acclaim V6. Steering becomes intermittently heavy when parking. No weird noises from pump etc. Car has 400,000 ish on the clock.
    Any ideas?
    Sam
    WTB: mulberry VN interior parts
    VZ SV6
    Oct 2008
    Newcastle NSW
    Low/uneven tyre pressures, worn steering rack, looseness/misalignment etc in the shaft/rack, failing pump, something else bent/damaged in the suspension (Radius rods etc)
    Although probably the pump or rack worn (maybe the belt?) causing low hydraulic pressure. I assume the fluid level's fine.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    My money would be on the belt or pump. Parking speeds (especially at full lock) require a lot more effort and put more pressure on the pump, which is driven by the drive belt. 400K is amazing if that's the original pump.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by alex2_s View Post
    Tyre pressures are maintained well, rack is original as far as I know, never been played with so won't be misalignment, could be developing looseness I guess, pump is also original as far as I know so may be that I suppose. Suspension hasn't ever had a hit so should be OK.
    Quote Originally Posted by BlackVXGTS View Post
    Belt is fine, replaced recently, could be the pump. Although, I wasn't aware that a failing pump could cause this sort of thing intermittently......? 95% of the time, even parking, it's fine. Then 5% of the time becomes a total nightmare.
  1. very heavy steering
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2012, 12:01 PM
  2. power steering very heavy
    By stewart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2008, 11:26 PM
  3. Heavy steering
    By thehsvmanv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-03-2007, 10:06 PM
  4. Heavy Steering.
    By ICUBYE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-08-2006, 04:35 PM
  5. Steering far too heavy in VT
    By Pezzer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2006, 10:04 AM
