Results 1 to 6 of 6
Thread: vx trip meter problem.
    VX series 2.
    Aug 2009
    Default vx trip meter problem.
    i have a v6 vx, and the trip meter on the dash wont reset when i hold both of the arrow buttons on together. is this a normal problem? any help would be good.
    2000 WH 5.7ltr Caprice
    Jan 2007
    Narellan NSW
    VX Executive S2
    May 2006
    Frankston South Vic
    Resetting the service due reminder.
    “With ignition off press arrow up and down arrow together then switch ignition on,
    after 3 seconds release arrows, then momentarily press mode button,
    then press arrow up and down arrow together for 3 seconds, then release arrows, then switch ignition off”
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    I think he means the trip meter not the service reminder.
    You should just hold the up/down arrows then release and it should reset if not then poss a problem with the cluster..
    If you wanted to you could try taking the neg terminal off the battery and if it reset that way might end up being a prob with the up/down buttons.. Do the up & down button control the menu options ok..
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Trav Man's Avatar
    Trav Man is offline Ya gotta love a V8 mate
    Black VX Berlina LS1
    Sep 2009
    Somewhere in this great southern land of OZ
    I had the same probblem with mine as it turned out that the switch pannel was faulty so I replaced it and all is good now.
    Trav Man
    I do what I do, Not because I have to, Not because I want to, But because I can
  1. Resetting Trip meter
    By Toms 50th Ani in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2012, 09:20 PM
  2. trip-meter
    By david25 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2010, 03:27 PM
  3. VS Calais Trip Meter Reading out
    By Sara Pax in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2008, 06:33 PM
  4. resetting trip meter
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 09:34 PM
  5. Trip meter
    By Fr3ak+-- in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2006, 09:34 PM
