Results 1 to 3 of 3
Thread: Commodore VX battery and car pick up problems
    commodore vx
    Nov 2009
    Default Commodore VX battery and car pick up problems
    i have 2 problems with my car and have no idea why they are happening
    first problem is my car completly shutting down whilst i was driving! had no steering, brakes where rock hard so had to use hand brake to stop, no lights on dash, NOTHING!! there was white corosion on batter. car started again and running fine since.
    second problem is when i drive a long distance and slow down corner or stop at traffic light my car will chug until revs reach 2 grand.
    any suggestions on why these problems are occuring are welcome!!
    VT Executive
    Aug 2007
    Timaru, NZ.
    Loose battery terminal for the first one possibly? or alternator about to die.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try pouring some warm water over the battery terminal to get rid of the corrosion then take the terminal off so you can give it a bit of a scrape to get rid of any scale that can act as an insulator and cause a bad connection. Give the battery terminal a bit of a scrape with a knife or something also. The battery terminal should be pretty soft because it is made of lead. If it is hard then it has a buildup of scale from corrosion that needs to be scraped off.
  1. Battery Problems?
    By Kid_Random in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 12:33 AM
  2. More Battery Problems
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 02:48 PM
  3. battery problems
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 02:49 PM
  4. battery problems
    By jerzey1234555 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2005, 09:45 PM
  5. More Battery Problems
    By G4orce in forum Electrical Wiring / Questions
    Last Post: 14-07-2005, 05:53 AM
