Results 1 to 10 of 10
Thread: VT 98 power steering fluid leak
    VT Acclaim 98
    Jun 2009
    Default VT 98 power steering fluid leak
    Hi
    i read on this blof about lucas power steering fluid leak stop.should i mix it with alredy filled steering fluid reservoir ....or how should i do it..
    please help
    sachi
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Do whatever the directions on the container advises.
    MY RIDE
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Would it not be more beneficial to you to fix the leak properly?
    VT Commodore S
    Nov 2009
    get it checked by a mechanic as soon as you can. I had a leak and got it checked by a mechanic. It was in the steering rack. $800 for parts + fitting
    vz acclaim
    Sep 2008
    I used lucas power steerind stop leak for a small leak and it is now all good.
    syringe out the amount of fluid to be replaced and all is well.
    no need for new rack in my case
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by Chriswl View Post
    hahaha, i did mine for around $200, fitted it myself.
    I regret not trying lucas power steering stop leak as I hear it swells worn seals, so what could be wrong with that? Couldn't hurt to try it even if it only last 10 or 20 thousand kays, that would still be a win.
    vt ss, vr calais, vt berlina wagon(family bus)
    Aug 2008
    adelaide
    check where the leak is 1st it might just be the o ring that has perished on the bottom of the power steering pump
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i did mine my self $250 for rack 3hrs to fit
    02 VT commodore
    Nov 2006
    Perth, West Aussie
    I put a $20.00 kit through mine and it is now working like a dream no leaks any where, all you need is a little grey matter between your ears.
  1. Power steering fluid leak - VP
    By LoZzA199 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2009, 11:34 PM
  2. power steering fluid leak
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2009, 03:00 PM
  3. Power steering fluid leak
    By Tuttle in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-06-2009, 06:43 PM
  4. Power steering Fluid leak
    By 410ci in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2009, 02:53 PM
  5. VN power steering fluid leak
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2006, 11:23 PM
