hi
im from the states and have a vt intake. im putting it on a 3.8 car over hear. i need to know the gm part number for the intake gaskets. i need all part number for the heads up. or can i get a complete upper motor gasket set. thanks
These are aluminium gaskets for the L32/ L67. They are re useable and are good for boost at all levels.
INTENSE-Racing.com: Lower Intake Gaskets (L67/L32)
If you're going for boost which I assume you are by using the VT plenum then some cometic MLS head gaskets are perfect
INTENSE-Racing.com: Cometic MLS Head Gaskets
INTENSE-Racing.com: 3800 - Gaskets & Hardware
VYII Calais L67
i need the part number for the vt holden intake. part numbers for the throttle body,the gasket between the upper and lower intake and lid.
