Results 1 to 7 of 7
Thread: problem with auto
    IBSK8N is offline skate L+R
    VS BT1 V6
    Nov 2009
    melbourne west subz
    Default problem with auto
    car: vx exec ser 2 v6 stock as a rock, 130,000k
    problem: when i open the throttle over half way and the auto changes into second and then trys to change to third it just jumps straight to neutral(100% DOES NOT SLIP). i have ran tec 2 on the car and it show that it jumps straight from 2nd to neutral.. i have changed 2,3 solenoid and the wires, auto elecs checked all the wires, bcm doesnt log a code, serviced it, and also the auto light doesnt come on
    please help!!
    VS BT1 V6
    Nov 2009
    melbourne west subz
    VT wagon
    Nov 2009
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    doesn it go into 3rd at all? if not then your clutches are worn out due to poor line pressures
    VXII
    Nov 2009
    Disconnect all wiring harnesses from the transmission and try to drive the car. It should go into limp mode and only select 3rd gear. Try selecting reverse also, it should work. By doing this you are using only the manual shift valve, therefore removing all electronic solenoids from the diagnosis.
    I don't have a pressure chart for a VS, but if you tell me what happens when you do these tests, we should be able to tell if a clutch has burnt out or a band is slipping.
    Also, when you drive the car and have tech2 plugged in, what are the pulse generators showing when in each gear? Do they all work properly? Do you have access to the live data?
    VT wagon
    Nov 2009
    Guys just got another auto and put it in and still the same thing slips when changing from 2nd to 3rd whilst accelarating but if crusising its fine? Could it be that the auto I got had the same issue? Anyone know of a decent auto place in the western suburbs?
    VT wagon
    Nov 2009
    Dude I had this same problem ended up being the ECU on the car was not sending enough Currnent to the TPS. I also changed the TPS also several times and still the same. So took it to Holden and a new ECU was needed got one from the wreckers and got holden to dial the new ECU in the car and problem gone
    Try lying the ECU on the passenger floor and car will not slip but still be laggy and change lazy.
  1. Vl auto problem
    By DONHOMER in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-02-2010, 09:29 AM
  2. vs auto problem
    By old8s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 01:52 PM
  3. Auto OD Problem
    By rosevs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 12:30 PM
  4. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
  5. problem with VR V6 auto
    By krizko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2005, 09:25 PM
