Hi there, new here
Oldies have a vx v6 auto
There is oil appearing in the radiator
Where should I start looking?
Thanks
what color is the oil ?? pink or brown ??
If you don't want to see oil in the radiator, don't look in there.....
Seriously though, inlet manifold gaskets are notorious for leaking on the ecotecs.
Its browny looking mud
check the spark plugs for signs of incorrect burn you have engine oil in the cooling system , it could be from blown head gasket or worn inlet gaskets or maybe the manifold has worn away , remove and check manifold gaskets and manifold condition if they ok move onto the cylinder heads and head gaskets checking oil passages thru head gaskets ..
could always be rust if its milky brown. my radiators rusting away atm![]()
1 VX Acclaim
1000's of possibilities
Are you sure it is oil and not just the residue from the tablets that lubricate the waterpump seal.
My Calais had a brown sludge in the coolant until i changed the coolant and did not put any pellets in the cooling system. Next time i changed the coolant i put the pellets in and i now have brown sludge in the coolant so i think it is the pellets that cause the brown sludge.
Lower intake manifold gasket(s) 99% of the time!
Had the same problem with my VT, searched and stressed for weeks. Bit the bullet, brought a Gregory's and got some priceless info from this site and did the job myself. Once there, the gaskets were cracked, warped and leaking.
2 day job for me (get a Gregory's) the car has no sign's of oil now for 2 months.
yeah if its brown inlet manifold
if its red = core in radiator is gone
otherwise low compression and brown hd gasket
As quombone said!!! Daughters car was same and just tightened gasket at rear water jacket.
mate i have exactly the same thing in my VT, pretty bad only takes couple of thousand k's til the green coolant turns to brown sludgy crap!
most likely intake manifold gasket, happened to mine. Pretty rare for head gasket to go in a VT from what I've heard.
