Results 1 to 12 of 12
Thread: water noise
    vt executive
    Jul 2008
    sunshine coast
    Default water noise
    just started my VT(V6) cold have never noticed before but windows up radio off and I could hear water wooshing when it turnded over then a tap on the throttle sounded like water running through my dash any ideas what is ???? cant hear it in engine bay or in the car with door open....
    VT Berlina S2
    Nov 2009
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    I get that as well, someone told me ones what it was but i forgot. Nothing to worry about though.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    means theres air trapped in the cooling system and needs bleeding
    The Blues Mobile
    Dec 2008
    Western Sydney
    Quote Originally Posted by delcowizzid View Post
    Crap, i thought it was something else! So do you mean a radiator flush is in order?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    nah just top up the radiator turn the heater onto hot start the car from cold wait for the hoses to build pressure and the engine to warm up then crack the bleed nipple on the thermostat housing and close it when air stops coming out may have to do it a few times to get it all outjust once theres no pressure in there from expanding water its easiest to let it cool down and do it again
    vt executive
    Jul 2008
    sunshine coast
    cheerz delcowizzid just bled it once its not as bad will do it again when its cooled down
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    to bled the cooling system correctly raise the coolant level above the bleeder nipple , simply topping up the rad and running will not remove the air 100% from the cooling sytem . use a funnel that will raise the coolant level above the bleeder nipple and while the engine is cold open the bleeder until water comes out close the bleeder and remove the funnel system is now bleed , check overflow bottle level .
    this applies to most v6's from series 2 vn onwards but not super chargered models different way to bleed them .
    в∞ѕтεכ √&
    Jul 2008
    NZ
    apart from you just left the whole heater assembly full of air just do it how its meant to be done no funnels etc will get it all out easy as air rises the bleeder is the highest point for that reason and to get the air out the heater the engine has to be running and the temp setting turned to hot
    scbh81's Avatar
    scbh81 is offline VRUUUM XU6 180 SC
    HSV XU6 VTII 99
    Jul 2005
    St Kilda Victoria
    Quote Originally Posted by strgas View Post
    What do u mean the supercharger models need to be bled differently? I flushed the system and opened all the bleed screws and left it open till water came out of all the bleed screws... is that wrong? I haven't had any issues like heating or anything?
    There is no such thing as 'What if?'
    http://forums.justcommodores.com.au/...y-hsv-xu6.html
    VT S1
    Nov 2009
    thanks for the post- i have noticed the same problem during the last month. I am also losing coolant in my VT gradually and have been told it can be due to a crack in the engine block- no leaks found when it was flushed and radiator replaced. I've been told something different by every mechanic I have been to however as I am not one I don't know what to believe. Any advice would be appreciated.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i agree with you do it by the mannual
  1. water noise behind dash
    By Force88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2009, 09:42 PM
  2. water noise behind dash?
    By GH05T in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2008, 10:44 PM
  3. Water noise from dash, i think!
    By dazza33 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2008, 09:32 AM
  4. water noise when starting
    By BobEddie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 11:18 AM
  5. Water in sill under doors, sloshing noise
    By Gravy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2005, 11:10 AM
