Results 1 to 8 of 8
Thread: identify this supercharger,causes of not boosting and mod plating
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    Default identify this supercharger,causes of not boosting and mod plating
    hey guys just picked up my new toy. its a 98 VT exec with a intercooled supercharger setup. only prob with it is its not boosting. got it for a bargain so wasnt complaining. when accelerating, you can here it whine above 2500-3000rpm so seems to be working but no boost pressure is reading at the guage and the guy said it doesnt have that oompf that it did when it was working. needs a new belt cause of cracking. just want to know what brand so i can get it in and checked out and get it working and replace the belt. theres no markings or stamps that i can see. also it probably does but do i need to get a modplate fitted for the setup? and no of any mobile ones around ipswich or where i can take it. oh and is there anyway i can test if it does have boost apart from guage.and just to clarify with the legal side of things there is no blowoff valve fitted. looks like one was but has been welded up
    http://s973.photobucket.com/albums/a...1000089JPG.jpg
    superchareger picture by blownVT - Photobucket
    P1000090JPG1.jpg picture by blownVT - Photobucket
    VT 2
    Nov 2008
    That looks a bit like a powerdyne Power plus . Check out CAPA who are an agent.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Looks like it has a bypass valve on the left side of the hose that goes from the intercooler pipe to the inlet pipe. I would say this valve is jammed open.
    Charged VT V6 A4
    Nov 2006
    Ipswich
    will check into them. been told looks like a vortech or capa system so far lol. as for the valve how would i check that. i have not had anything to do with these chargers before.
    VL V8 & supercharged VX
    Nov 2006
    western vic
    Charged VT V6 A4
    Nov 2006
    Ipswich
    yep done some looking into mainly through cappa's site and yep its a powerdyne system. now to order new belts and work out the boosting problem.
    BIG-EV's Avatar
    BIG-EV is online now Project VT (In Progress)
    2000 VTII Executive 3.8L Supercharged V6 Wagon
    Oct 2008
    Mango Hill QLD
    Charged VT V6 A4
    Nov 2006
    Ipswich
    gone over everything seems to be ok...one hose going to under the one of the pipes is bit brittle and loose will change that. took the bypass valve and and is not jammed open or closed can open it with a finger. getting plated on wednesday so will park it up and have a good check over. thinking of upgrading the charger to a better model if i can get one
  1. boosting a carby
    By Nzpure in forum V8 Development and Modification
    Last Post: 22-09-2009, 11:51 AM
  2. [Buick] Boosting up - 2 or 3 Bar MAP sensor
    By JA2Z in forum V6 Development And Modification
    Last Post: 22-07-2009, 09:45 AM
  3. Boosting up - Use 2 or 3 Bar MAP sensor??
    By JA2Z in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2009, 05:56 PM
  4. Boosting an Ecotec
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2008, 09:46 AM
  5. 202 Power Boosting
    By Mr Robbo - The General in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-05-2006, 05:01 PM
