hi guys, just wondering if anyone has any info on vt senator with the 5litre in it. Just bought one and pick it up later this week but cant seem to find any info on them. Wanted to see what specs the motor etc, if anyone knows anything that would be great.
cheers sean
my bad, its a 195
'V' configuration. OHV design with cross flow cylinder heads. 'Hot wire' air mass metering. Sequential fuel injection. Engine management system. Computer diagnostics. Twin electric cooling fans. Stainless steel exhaust. High flow air cleaner. Low restriction dual exhaust. Breakerless high energy electronic ignition system. Knock-control sensor. Low friction technology.
Replaced by 5.7L V8 in VT Series II.
Cylinders: V8
Capacity: 4.987L
Bore x Stroke (mm): 102.0 x 77.0
Induction: Electronic sequential fuel injection.
Valvetrain: Overhead valves, pushrods, 2 valves / cylinder.
Compression ratio: 8.8 : 1
Maximum power: 179 kW @ 4800 RPM
Maximum torque: 400 Nm @ 3600 RPM
Redline / Cutout:
The 5ltr, 195i is a HSV enhanced Holden 5ltr V8 engine, which if I recall correctly uses HSV headers, and the use of knock sensor, and a tune to produce 195kws at the flywheel.
I believe the quoted statement is incorect, the 220i is actually a 355ci stroked Holden V8 with similar enhancements to the 195i, and produced 220kws at the flywheel, I dear say it would have been an option because I haven't seen many around. Both the 195i and 220i are found in early model (97/98) VT Senators, Clubbie and GTS's.
From 1999 onward (Series two) I am pretty sure they used the "Gen 3" which in the Senator's were rated to 250kw at the flywheel.
The Senators are beautiful car's so it's certainly a good pickup if it has low km's on it. Pictures are a must, so please shear when you pick her up :-)
151 Countries, One Cúl-Báire!
Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
Cúl's AUII XR8 Ute!!!... Clicky Clicky!
220 in the 5.7L stroker.
The 5L only had 195.
the gts-r was a 235kw stroker i think in the vs ones.the vt senator came with the 195kw 5l ,the 220kw stroker and the series 2 ls1 250kw. if you have a choice of all three go the ls1![]()
Hey guys thanks for the msgs, I pick the car up thursday so will post some pics on. Its 98 senator sig 195i, 124k on clock, Raven Mica in colour and vy gts rims
Nope, if you read my post again from late 98 / 99 or series two onwards they ran with the "Gen 3". Only the earlier Senators had the 195i or the 220i powerplant.
Regardless of what power plant they have, they are very nice cars, I am looking at trying to fill my stable with one at the moment ;-)
looks awesome on the gts's how much was the car if you dont mind me askin
We have the series 2 with the LS1. Awesome car.
got it for 14k on road, so pretty good as its in really good nick. Hard to find out info on them for some reason. Pick it up Wed or thurs so should be good but bit diff as always had fords before this. Anyone know what these would do the 1/4 mile in??
