Results 1 to 7 of 7
Thread: "think" i have a heating problem,please help
    02' VXii Exec 9C1
    Aug 2009
    Default "think" i have a heating problem,please help
    hey guys
    i have a problem that i "think" is a heating problem
    today on the way to work i had the A/C on and was driving and heard a belt slipping noise.
    turned the A/C off as i was close to work and made it my goal to just get there.
    pop the hood,everything was fine.it was heard around 2000 rpm till 2300-2400 rpm
    i go home from work and the slipping noise is gone thinking great.i have the A/C.about half way home,i hear a large bang and think ive just gone over something,i didnt see anything on the road but it was night.not long after this my car beeps at me and i see HOT on my dash window.now i had just looked at the temp gauge a second ago and it was normal.now it was in the red.i pull over and pop the hood,everything seems fine and i let it cool down.
    i drive home (it was only a few minutes,also with the A/C off) and discover that my radiator is bone dry,i filled it with some water to just do a few tests.
    no leaks were found,it holds correct pressure also,so far so good you would think.
    when i started the car the radiator fans didnt turn on...is this normal?
    i let it idle a little and still no fans on.
    i then turned the A/C on and only the passenger side fan started.
    through all of this the temp gauge seemed normal...or only a little bit over
    i know ive written a long post but thought giving every detail might help if anyone has any ideas.thanks guys
    First Car: 01' VX S
    Second Car: 02' VXii Exec 9C1
    VT Berlina S2
    Nov 2009
    first of all you need to find the reason why your radiator was empty, there must be a leak somewhere.
    coolant can leak from lots of different places, radiator, hoses, water pump, head gasket, heater hoses.
    i dont have much experience with commodore water pumps, but a water pump i had on a holden apollo was failing, it was only leaking when the sytem had completley cooled and had been sitting for a few hours, when i was driving, there were no leaks because of the pressure build up.
    VZ SV8
    Nov 2009
    Ive.. replaced 2 heater taps on my mums VX.. Id check there also
    It's on the drivers side almost on the firewall..
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    try bleeding the cooling system correctly then recheck for leaks as air can be compressed and the cooling system wont reach its operating pressure correctly . is the car on gas ? Is there coolant in your system or just water??
    02' VXii Exec 9C1
    Aug 2009
    the car isn't on gas.there was coolant in the radiator but i havnt got any around the house so for now just water.the water pump was replaced just after last Christmas.nothing has leaked onto the floor,if id did i have cream floor under the car so i would see it easily.but its leaking somewhere because the water i put in last night wasn't there this morning.hopefully it just a hose...its getting a full check over tomorrow.could the radiator need replacing?
    First Car: 01' VX S
    VT Berlina S2
    Nov 2009
    02' VXii Exec 9C1
    Aug 2009
    Quote Originally Posted by bundy_boy View Post
    have you checked your oil to see if coolant/water getting in ?
    yeah,checked after it happened,which means i dont have a blown head gasket.
    so far verdict is need a new radiator
    First Car: 01' VX S
  1. Do "police pack" cars have a standard v6 or the "high output" one?
    By Gibson_83 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-08-2011, 05:42 AM
  2. Over Heating then "Check power tran" warning
    By LLorry in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-04-2009, 04:29 PM
  3. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  4. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  5. "Start ya Ba*tard!" Kind of a problem but not really..
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-08-2006, 11:26 PM
