Results 1 to 9 of 9
Thread: stiff accelerator pedal
    vt ss, vr calais, vt berlina wagon(family bus)
    Aug 2008
    adelaide
    Default stiff accelerator pedal
    as the title suggests just wondered if anyone has had this? also a small amount of play before the car accelerates. does the cable need changing or just the pedal needs adjusting and lubing up
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by picks View Post
    The cable can be adjusted up near the throttle body. Disconnect the cable and and see if the pedal and cable move freely.
    MY RIDE
    99' VT commodore
    Sep 2009
    Rockvegas
    A car enthusiast of a 10 second charger aka lucas, once said to me 'regardless of whats in your car, the only thing you need to feel is your accelerator'
    Sladdo is offline Resident Ford mechanic
    HBD VT V6 5sp Exec.
    Jan 2009
    Murwillumbah
    Is your car series one or two?
    Series one had a longer cable which ran around the shock tower & over time would get crushed by having the bonnet closed on it thus making it stiff. Series two ran a shorter cable which came around before the shock tower. They arent expensive. About $40 from your Holden dealer trade price & not hard to replace.
    Aug 2008
    adelaide
    its the missis s car, she s complain about it. its a series 1. cheers for replies guys ill check it out.
    vt calais
    Feb 2007
    check if the thottle body needs cleaning mine done that when i got it give it a good clean every service now
    vt s s1
    Mar 2009
    Stiffness will be due to carbon build up around the butterfly of the throttle body causing friction.
    Youl probably find once the car has heated up its not so bad.
    Just give the thottle body a good clean out with some carby cleaner.
    vt 1999
    Dec 2008
    vt 1999
    my car do that only when it is heated up is that related to bad cable or not please help me?
  1. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  2. accelerator pedal
    By 94calais in forum General
    Last Post: 21-11-2008, 09:52 PM
  3. Stiff accelerator
    By VXIIwagdf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2006, 10:11 AM
  4. VS Accelerator Pedal
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 07:26 PM
  5. Accelerator stiff
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2005, 12:13 PM
