Results 1 to 16 of 16
Thread: yella terra or mace engineering air intake
    vu executive ute
    Jun 2009
    Default yella terra or mace engineering air intake
    was wondering which air intake people recommend i get out of the yella terra and mace engineering intakes for my vu v6 ute and peoples experiences with both thanks
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    vt s pac
    Sep 2008
    I installed the mace cold air intake on the mrs car and it works pretty good, its a enclosed pod filter.
    when i got mine it had a ss inductions over raidiator cai and ive hooked up a yella terra ram air pipe that has helped the vac a bit.
    I would have gone the enclosed pod if i didnt already have the otr installed....
    Cheers,
    Ben
    S.T.K.E's Avatar
    S.T.K.E is offline Wiggle Wiggle Wiggle
    Holden Jackaroo 3.0TD
    Mar 2009
    Brisbane Northside
    STKE's Ride: http://forums.justcommodores.com.au/...lais-3-8s.html
    Quote Originally Posted by Tim Smtih
    Also you could just whisper in his ear "guess what i did to your mum last night?" And walk away laughing.
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    the homemade cai is crap! i did it on my vt and did not make a difference in power, you pick up the hot road air and shit loads more dust!!! i had to clean my k&n air filter every 5 thousand k's. you will regret doing it and then you'll have to buy a new air box because you cut a hole in it.
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    why do an inclosed pod filter? how is that any different to a air box with a filter, it's still only gonna have a small inlet?
    VX Executive
    Feb 2009
    lol so true.. people think pods have a larger area thus can suck more.
    1 VX Acclaim
    1000's of possibilities
    vt s s1
    Mar 2009
    Quote Originally Posted by Maxseverity View Post
    probably cos its true maybe...
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    but they suck the heat off the motor defeeting the purpose of more air, your motor loves cold dense air, hot air is very thin and therefore you need need more to get the same volume into the motor.
    Suzuki Swift GTI
    Dec 2008
    cessnock
    Quote Originally Posted by ducker85 View Post
    If the pod is enclosed in a box it would be no different from a normal filter in the box. but if it has a ram air effect into the box it shouldnt be sucking hot air from the engine.
    To add speed, first you must add lightness
    Quote Originally Posted by walesy View Post
    I had the same problem when i was 12 in my 383 twin turbo double supercharged hk monaro bit i put one of the turbos in the boot and one of the superchargers behind my drivers seat, so much better for my paint... and my penis which i had obviously been playing with too much thinking bout it.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    i have the mace cold air enclosure with pod i previously had a k&n panel filter and an OTR the Mace enclosure is heaps better then my old setup
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VT 2
    Nov 2008
    MACE enclosure.
    Air is drawn from the cooler positive pressure aree in front of the radiator, behind the headlight, when moving.
    MACE enclosure uses a pod as it presents a l;arger surface area than a panel filter. This means more air can be filtered at any given moment, and is therefore less of a hindernace to air entry to the manifold.
    Plus - in the VT's theres a filler panel beside the radiator that covers a large air vent hole, cut it away and you have a direct air path into the MACE CAI. I uploaded photo's somewhere....
    Beware of anything that sits above the radiator. The operating temp of the radiator is over 87 degrees c, this is a HOT spot. Heating any incoming air is the opposite of intercooling it. Bad. (well - not catastrophic, but is certainly the enemy of performance AND economy).
    ducker85's Avatar
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by Tsunamix View Post
    MACE enclosure.
    Cheers some1 who a an enclosed pod and knows what there talking about. would love to see that pictures if you can find it. I was gonna put the FIT type 'S' air box in my VT but your starting to change my mind, im just not a fan of the datsun whistle you get from stock standard pods like those fitted to stock standard VL's
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    MACE enclosure.
    Mate I beg to differ the people that has an OTR CAI next time you go for a drive when you stop pop the bonnet and put your hand into it and see what tempreture it is I can gaurantee that it's not hot why cause it has alot more air rushing over and through it than what it has coming up from underneath and the fact that you are moving forward any air coming up from the radiator will get blown back towards the engine not the CAI.
  15. #15
    VY s m5 supercharged
    Aug 2008
    save your self some money and make your self a home made cai not like the ones above do a search and pick one that you like and go from there.
    I just make one up for dads VT SS and it made a huge difference and i cant see that spending a few hundred on a brand one would have made any difference and if it did it wouldnt worth the extra cash by any means. It also looks nearly factory and you have to have a good look to even pick it.
    and no i didnt cut any part of the car but the air box.
  16. #16
    Mar 2008
    Here is a link to some practical results that immortality has done between the factory OTR and our cold air intake system
    MACE Cold Air Intake
  1. Mace Engineering Development Car
    By VS_WPN in forum Mace Engineering
    Last Post: 11-06-2010, 11:35 AM
  2. MACE ENGINEERING 1.9 roller rockers
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2009, 02:54 PM
  3. cold air intake mace engineering v6 vy
    By imartinoski in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-01-2009, 12:47 PM
  4. [SA] 5L CAI (mace engineering)
    By 96SEN8R in forum Parts And Other Items For Sale
    Last Post: 23-01-2009, 01:11 PM
  5. Yella Terra Terra Charger
    By INDACLUB in forum Yella Terra
    Last Post: 22-09-2008, 09:12 AM
