Results 1 to 13 of 13
Thread: Vx S2 Brakes
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Question Vx S2 Brakes
    Hi guys, just wondering if it is difficult to change the brakes front and rear. I gotta a quote for $768 rotors, pads and fitting which at the moment is expensive for me especially coming up to Xmas. I want to save myself a bit of money and learn to do the job myself.
    Is this hard to do and what tools will be needed? Is there a procedure for this? Any suggestions on what brands to go for and also standard vented or vented drilled rotors? I have gone for cheap brands or whatever they put on and they don't seem to last long.
    Cheers.
    VTvoodoo's Avatar
    VTvoodoo is offline 99 VT S2
    VT Executive S2
    May 2006
    Gold Coast
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Can be a difficult job especially those rear rotors because of the handbrake. The bolts on the calipers are super tight so you will need decent tools to remove it as they are covered in locktight. $768.00 doesn't sound to unreasonable for 4 rotors and pads + fitting.
    VXII
    Nov 2009
    Repco have 2 x discs, pads and brake fluid for $99, front or rear for all commodore models. In the latest catalogue.
    Ok quality too.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Ray De Man View Post
    What are you using the car for? Is it just a street car?
    Our recommendation for entry level brakes is QFM HPX pads (made on the Gold Coast, Bendix Ultimate equivalent, but very low dust and rotor wear), and RDA standard rotors.
    For front and rear HPX and RDA rotors for the VX you're looking at $328, plus about $15 shipping to you.
    Otherwise for cheap cheap, the $99 Repco deal is unbeatable. But if you're going to to do the work yourself you may as well start with decent parts...
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Cheers guys for that info. Will be attemping it tomorrow. GSLRALLYSPORT thanks for the reply but I guess I should of posted earlier to buy them off you. Repco deal is unbelieveable value but will still be putting cheap crap parts as brakes. Think i'll get the RDA rotor's from super cheap or somewhere.
    The thing is I had brakes done in Feb this year, new brake fluid, front pads + rotors and rears rotors skimmed. I do alot of driving and yes this a daliy driven car so cheap stuff just aint gonna cut it.
    Just a question, do I need to flush the system again when applying new pads and rotors? Is there different sizes between the front and rear rotors?
    vt s s1
    Mar 2009
    If you had your rotors done this year are you sure they need replacing?
    No you dont have to flush the system
    Yes they are different size, the fronts will be ventilated while the rears are solid.
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Thanks bud. Yeah they need doing, front rotors have blue lines and has hot spots. The rears squeak when braking. Im also experiencing vibration when I guess is from the fronts.
    Anyway I now have DBA slotted front rotors with Bendix pads and the rear DBA solid rotors with Bendix pads. Hopefully the extra expence will pay off and last longer then those cheap-o brands.
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    I did rotors and pads on a VT and it cost me under $200,thats with new caliper bolts.
    Are we there yet?
    vt s s1
    Mar 2009
    You should maybe ring round some brake shops to find out how much it would be for them to just machine them as im sure theyd have plently left on them.
    Would probably save you money on just buying new rotors.
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Did all the brake on the weekend. Brakes really well now and no vibrations at all. I followed the bedding in process but I am experiencing a squeek from the rear brakes when applying brakes, fronts are quiet as a mouse. What can I do to stop that noise? Does it take longer for the rears to bed in as the fronts do most of the work?
    Oh total cost of all pads and rotors front and rear came to just under $450. Not bad I guess plus I learnt how to do it and saved money getting someone to fit them ;-)
    vt s s1
    Mar 2009
    Did you put brake quiet on there?
    If you did could be the compund of the pad.
    VZ SV6 && 180sx
    Mar 2008
    Reverse doing about 50km/h and brake hard, repeat 4-5 times... Or untill you can smell the pads.
    This should get rid of the squeak.
    PS. Try this somewhere secluded haha.
    WTB: VZ Chasers
  1. [WA] Wtb hsv brakes
    By younglion in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 12:58 PM
  2. VN Brakes
    By elemeNtz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 09:35 AM
  3. No brakes!!
    By milkandjuicecomein2litres in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2009, 11:55 AM
  4. vt brakes on vp v8
    By v8_bomberdore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2009, 09:46 PM
  5. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
