Results 1 to 7 of 7
Thread: vt fuel lid
    VT Commodore S Pack
    Nov 2009
    Default vt fuel lid
    anyone got any idea how to remove the fuel lid? mines peeling a fair bit and to my luck ive found another fuel lid lying around in the garage but im unsure on how to take the old one out and chuck in the one ive found?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Open the lid and there should be 2 screws to undo.
    MY RIDE
    VT Commodore S Pack
    Nov 2009
    oh ok, that was quite easy. thanks.
    i've just realized that the whole hinge piece is missing off the one ive found. got any ideas on how to replace it? i was thinking of sanding down the excess plastic left of the snapped hinge, cutting off the hinge off the old fuel lid and gluing it to the one ive found. or will that not work?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It should work if you use a strong enough glue. It might be easier to get one from the wreckers, hopefully in the same colour. It shouldn't cost very much.
    MY RIDE
    VT Commodore S Pack
    Nov 2009
    i headed off to the nearest dealership n picked a new one up for around $30. whats the process id go through to paint it? i heard the guy behind the counter saying something about plastic primer?
    Wombles's Avatar
    Wombles is online now Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Probably get a panel beaters to spray it cause the touch up paint may not be the same colour as your car...
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VT Commodore S Pack
    Nov 2009
    any idea on how much that would cost?
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. Fuel Line removal tools for Fuel Filter
    By vxcalais_01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 09:56 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
