Results 1 to 7 of 7
Thread: Throttle body
    Vt Commodore Acclaim
    Aug 2009
    Default Throttle body
    Im looking at installing a 70mm throttle body. Will i use more fuel and just gain power or make it run more efficiently and use less like extractors?
    VP Executive R-spec
    Jan 2005
    It'll make your throttle more touchy, highly unlikely to do much of anything else. I put a 70mm on my 5 litre after a very long time of believing it didnt need one, just to see. I got
    Zero point Zero gain on the track
    VXII
    Nov 2009
    I agree completely with greenfoam.
    You might even be lucky and confuse the engine management system and lose power/efficiency. The computer fuel mapping is programmed to inject x amount of fuel at y throttle opening, and expects z amount of air to flow through the inlet at that time (there's a lot more than this involved, but keep it simple).
    If you change the throttle size, you change the air flow rate, and the fuel system is no longer calibrated.
    Any effects (good or bad) will be felt most at low throttle opening - it will probably run lean on acceleration, but these effects will lessen the more throttle is opened, to no difference to full throttle.
    You inlet tract has very few restrictions in it. Leave it the way it is. If you don't believe me, connect a manometer (vacuum guage) and go for a full throttle drive and check manifold vacuum. You will find it has very minimal vacuum, meaning no restrictions.
    VT 2
    Nov 2008
    It Depends on the engine.
    With the ecotec Auto's, the larger throttle body helps to remove the doughy bottom end response. It doesn NOT affect maximum performance really, as 68mm allows enough air in anyway.
    When you have added a few other mods, insulators, extractors, high ratio rockers at least, you may see small gains from the oversize TB as your engine will need a little more airflow at the top end.
    Once you go a custom tune with a raised red line plus above mods, you will see noticeable benefit.
    The major reason for going OS TB is low down throttle response.
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Tsunamix View Post
    agree i have all them mods as said above plus a few little extra's and i did notice it quite alot
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Aug 2009
    My VT already has Pacemaker extractors and a highflow cat and a lukey catback as well as a K&N Panel filter which im looking to upgrade to a SS Inductions Cold Air Intake soon, which is why I was thinking of the throttle body.
    VT 2
    Nov 2008
    With the mods you have, you won't see much if any benefit in terms of peak power / torque. You don't have any mods that make the enginee consume more air, your mods just allow it to consume it's standard capacities more effeciently.
    Add cam or high ratio rockers, or forced induction or a custom tune and you will see noticeable benefits. I'd leave it low on the list of priorities right now. I would suggest high ratio rockers, insulators and a foamtune first.
  1. v8 throttle body
    By s65481 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-09-2009, 12:42 PM
  2. Throttle body
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-03-2009, 02:53 PM
  3. throttle body
    By dimetime in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2009, 04:31 PM
  4. wtd vn-vr v8 throttle body
    By vr5speed in forum Swap / Wanted to Buy / Trade
    Last Post: 07-10-2006, 03:27 PM
  5. XF Throttle body for VL
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2005, 08:35 PM
