i had a quick search but nothing,
my left hand side power window stop working after i removed my ECU to get chipped! i have voltage at the plug and window switch is used! does this mean the motor on the window is stuffed? please some one let me no so i can fix it or buy a new one!
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
To check the regulator motor connect 12 volts directly to the terminals on the motor. It doesn't really matter which way you connect the 12 volts, it will either go up or down and if you reverse the wires it will go in the opposite direction. If the motor works you could have a broken wire in the door loom, inside the rubber boot between the door and body.
MY RIDE
righto ill give it ago thanks mate!
so as said before my power window stop working can some one tell me where to get a replacement one from, i wanna change it before the xmas holidays start! i got the last one from ebay last year, it only lasted 15 or so months. any where else as cheap and quick to pick up?
any one?...................................
