Results 1 to 3 of 3
Thread: vt series 2 problems...help
    1999 Vt Series 2 Olympic Edition
    Nov 2009
    Craigmore, Sa
    Default vt series 2 problems...help
    Hey
    I have had my vt for about two weeks now and have noticed a few problems with it
    Power aerial wont go fully down/up and makes clicking noise when trying
    powersocket wont work at all
    switch for drivers side power window wont work
    any ideas on how to fix these and where to get the parts for the job
    thanx
    VYII Berlina 3.8, VE Calais V 6L
    Aug 2005
    Common problem on all commos mate. Happened on my VS and VT. Same thing - won't move much and makes the clicking noise. I believe you will just have to get a new electric aerial for it, or if the motor is okay, I think you can just get the metal aerial stalk and get it fitted no worries. I don't know exactly how to replace the aerial on the VT but I know on my old VS, you had to remove the quarter panel and all. I just got a bloke to do it for me.
    As for the power socket, could be a lose wire, farked fuse... don't really know for that one. Make sure you have tried two different appliances :P
    Power window button could of had some sort of beverage spilt on it, so look into getting a new one. You will have to get a whole new power window button thing. But don't do this straight away, the whole power window might be rooted or a cable somewhere along the lines is stuffed. If this is the case, replacing the power window button won't do a thing. You need to check to see if there is electricity getting to the power window motor before you make any decision... easier said than done lol.
    Good luck
    Ben.
    Nov 2009
    Craigmore, Sa
    thanx man
  1. VY SS Series 2 -problems
    By pjwooly in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-02-2009, 11:02 PM
  2. VX SERIES 2 Problems !
    By ucd939 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-03-2008, 05:55 PM
  3. Many problems wif vs series ones?
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2006, 09:57 PM
  4. Problems replacing a series 1 with a series 2
    By Rhino Racing in forum V6 Development And Modification
    Last Post: 09-09-2005, 09:50 AM
  5. vr series II ignition problems
    By joem in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2004, 01:40 AM
